NDI
Problem with Local Desktop Capture
Hello. I have a problem with Local Desktop Capture. On first notebok there is only black screen but second machine is crashing and turns off when I add excel or program to scoreboard. Is someone knowwhere a problem is ? Problem is visible on film which is on link below
Originally Posted by: doggy  https://www.vmix.com/knowledgebase/article.aspx/42/blank-screen-when-using-desktop-capture It was working 2 month ago on the same notebook with the same system windows 10. It stoped working 2 month ago. Interesting is, that it's working exelent on my pc, where I have also windows 10 and also gtx 1060.
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
does your laptops have Dual GPU's? Intel and Nvidia? I have had a similar problem before, it is about witch gpu is bieng used for the application. Just use NDI Scan Converter and it should work, is one way to go. try that
NDI
