bgbenni
#1 Posted : Friday, August 16, 2019 6:36:49 AM(UTC)
bgbenni
Germany
Hallo is it possible to change the separation from vmix for the database from , to a other information ;
#2 Posted : Friday, August 16, 2019 6:52:31 AM(UTC)
Are you talking about CSV files? how do you create them?
bgbenni
#3 Posted : Friday, August 16, 2019 7:40:14 AM(UTC)
bgbenni
Germany
Yes is is a csv file a can creat the file with , ore ; the problem is if I have a information inside the csv with 12,34 it’s splits the I formation.
#4 Posted : Friday, August 16, 2019 7:52:18 AM(UTC)
change the decimal depiction to a period instead in your excel setting (language)
richardgatarski
#5 Posted : Friday, August 16, 2019 3:56:48 PM(UTC)
richardgatarski
"vMix Basic","Free"
"vMix Basic HD","0,06 k$"
"vMix SD","0,15 k$"
#6 Posted : Friday, August 16, 2019 4:07:08 PM(UTC)
@Richard
doesn't work if you have
"vMix Basic","Free"
"vMix Basic HD","0,06"
"vMix SD","0,15"
drops the leading zero's and the comma for the numbers
richardgatarski
#7 Posted : Friday, August 16, 2019 6:57:15 PM(UTC)
richardgatarski
darn, you're right...
Found and old topic https://forums.vmix.com/...l-data-format-number-bug
Not sure if it's (still) a bug, or that some of us users don't know how to do it.
In any case, it seems to me that the formatting applies to how thinks are displayed in the Title. There is no corresponding formatting setting in DataSource Manager, nor possible to specify if a particular field is supposed to be a numeric or interpreted as a number.
#8 Posted : Friday, August 16, 2019 7:08:10 PM(UTC)
Yeah but nit putting it in a title yet
IMO its a bug as technically the data comes from a textfile and i guess depends on how vMix treats that data in the first place. if it finds anything that is not a digit it treats the whole field as a text , else as a number disregarding the comma (i think)
