Data Sources separation lines , ; ?
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Hallo is it possible to change the separation from vmix for the database from , to a other information ;
Are you talking about CSV files? how do you create them?
Yes is is a csv file a can creat the file with , ore ; the problem is if I have a information inside the csv with 12,34 it’s splits the I formation.
change the decimal depiction to a period instead in your excel setting (language)
"vMix Basic","Free" "vMix Basic HD","0,06 k$" "vMix SD","0,15 k$"
@Richard
doesn't work if you have
"vMix Basic","Free" "vMix Basic HD","0,06" "vMix SD","0,15"
drops the leading zero's and the comma for the numbers
darn, you're right... Found and old topic https://forums.vmix.com/...l-data-format-number-bugNot sure if it's (still) a bug, or that some of us users don't know how to do it. In any case, it seems to me that the formatting applies to how thinks are displayed in the Title. There is no corresponding formatting setting in DataSource Manager, nor possible to specify if a particular field is supposed to be a numeric or interpreted as a number.
Yeah but nit putting it in a title yet IMO its a bug as technically the data comes from a textfile and i guess depends on how vMix treats that data in the first place. if it finds anything that is not a digit it treats the whole field as a text , else as a number disregarding the comma (i think)
