shawntempesta
#1 Posted : Tuesday, August 6, 2019 10:08:27 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
As it says, since the update, sending the update over flies in the graphic, but doesn't update the fields so the last picture and text loaded appear. Anyone else?
#2 Posted : Tuesday, August 6, 2019 11:17:09 AM(UTC)
If you are using a custom title template with text fields with special characters (hyphens dashes etc) you may need
to reapply the mappings in vMix Social from Edit Mappings as we had to fix a bug with some users using spaces in their field names.
Otherwise, it should all work as normal with the built in templates.
ask
#3 Posted : Tuesday, August 6, 2019 11:31:05 AM(UTC)
ask
Just tested with FB feed. All good. Check your Rotation and repeat setting. Also try clearing your queue and untick "Queued Entries Only"
