vMix Social Not Updating After .67 Update
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
As it says, since the update, sending the update over flies in the graphic, but doesn't update the fields so the last picture and text loaded appear. Anyone else?
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
If you are using a custom title template with text fields with special characters (hyphens dashes etc) you may need to reapply the mappings in vMix Social from Edit Mappings as we had to fix a bug with some users using spaces in their field names.
Otherwise, it should all work as normal with the built in templates.
Martin vMix
Just tested with FB feed. All good. Check your Rotation and repeat setting. Also try clearing your queue and untick "Queued Entries Only"
