sacchin
#1 Posted : Thursday, July 25, 2019 12:04:06 AM(UTC)
sacchin
Hi all,
I was wondering if anyone knew of any inexpensive cameras which can be used with vMix.
I currently have 2 x Sony PXW-X70 camcorders which work perfectly.
I need another camera which will take a long wide angle view for a party hall so it will be mounted in one place.
I have seen that there is a webcam "Logitech C920 HD Pro" but is there anything else?
thanks
mjgraves
#2 Posted : Thursday, July 25, 2019 2:14:21 AM(UTC)
mjgraves
Logitech webcams works with vMix. I've used many different models, including the C920.
Some have noted that the Logitech Brio 4K webcam can fake PTZ when used in a production that operates at 720p or 1080p. I find it to be noisy when compared to the admittedly more costly Logitech PTZ Pro 2.
sacchin
#3 Posted : Thursday, July 25, 2019 2:50:29 AM(UTC)
sacchin
Perfect.
Thanks for this.
I think I might just purchase the C920 as its probably the cheapest option and heard good reviews about it.
Similar Topics
zoom livetrak L-8 VMIX compatibility (Hardware Compatibility)
by jaialai 6/17/2024 4:32:07 AM(UTC)
vMix compatibility with OBS plugins (General Discussion)
by RobertG 6/7/2022 11:51:08 AM(UTC)
Nvidia Creator Ready Drivers and VMIX compatibility (Hardware Compatibility)
by John Barson 11/6/2019 9:03:08 AM(UTC)
How do I verify vMix compatibility with a network camera? (Hardware Compatibility)
by dansimard@gmail.com 5/31/2019 6:01:05 AM(UTC)
Pc x vmix compatibility (Hardware Compatibility)
by attilio18 10/25/2018 12:40:05 AM(UTC)
