Hi all,
I was wondering if anyone knew of any inexpensive cameras which can be used with vMix. I currently have 2 x Sony PXW-X70 camcorders which work perfectly.
I need another camera which will take a long wide angle view for a party hall so it will be mounted in one place.
I have seen that there is a webcam "Logitech C920 HD Pro" but is there anything else?
thanks
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Logitech webcams works with vMix. I've used many different models, including the C920.
Some have noted that the Logitech Brio 4K webcam can fake PTZ when used in a production that operates at 720p or 1080p. I find it to be noisy when compared to the admittedly more costly Logitech PTZ Pro 2.
Perfect. Thanks for this. I think I might just purchase the C920 as its probably the cheapest option and heard good reviews about it.
