GT
Scaling a graphic/rectangle to text width
I've been looking around but can't find any info on this:
Is it possible to create an auto-scaling background (image or a simple rectangle) for text? This is crucial for Lower thirds, so you're not left with whitespace or text falling out of the background graphic.
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi
Have you tried using the Mask feature underneath the Effects Tab
To create a mask create a rectangle say with white bg and then some black text.
Place the text over your rectangle and then with the text active select Effects Tab -> Mask
Then select the rectangle as the masking object
That doesn't do anything. If I do it the other way round (selecting the rectangle and then masking using the text layer) I get a tiny outline on the text similar to a stroke but not controllable.
So in short: that doesnt work.
Thanks for the suggestion though.
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
there are fonts that have box backgrounds if that's a workaround you're looking for
GT
