Loccufier
#1 Posted : Monday, June 24, 2019 11:12:15 PM(UTC)
Loccufier
I've been looking around but can't find any info on this:
Is it possible to create an auto-scaling background (image or a simple rectangle) for text? This is crucial for Lower thirds, so you're not left with whitespace or text falling out of the background graphic.
Ash
#2 Posted : Tuesday, June 25, 2019 6:50:01 AM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
Hi
Have you tried using the Mask feature underneath the Effects Tab
To create a mask create a rectangle say with white bg and then some black text.
Place the text over your rectangle and then with the text active select Effects Tab -> Mask
Then select the rectangle as the masking object
Loccufier
#3 Posted : Tuesday, June 25, 2019 8:53:00 PM(UTC)
Loccufier
That doesn't do anything.
If I do it the other way round (selecting the rectangle and then masking using the text layer) I get a tiny outline on the text similar to a stroke but not controllable.
So in short: that doesnt work.
Thanks for the suggestion though.
richardgatarski
#4 Posted : Tuesday, June 25, 2019 9:30:42 PM(UTC)
richardgatarski
Loccufier, consider adding your vote at https://forums.vmix.com/...nd-following-text-length
Barney Box Lane
#5 Posted : Thursday, July 4, 2019 9:32:11 PM(UTC)
Barney Box Lane
there are fonts that have box backgrounds if that's a workaround you're looking for
