Teye
#1 Posted : Thursday, June 6, 2019 7:23:33 AM(UTC)
Teye
Hi All,
Just installed vmix 22 and none of my webcams are working properly.
the inputs are jittery and flicker a little. system is loafing along.
reinstalled vmix 21.58 and all is well. Webcams work fine with other apps too.
my system: acer aspire V 15 Nitro
OS: windows 10 home latest updates
Video card: Nvidia 945m
CPU: I7 6500U
RAM: 8 gigs ddr4
webcams: c920, c930e and builtin cam
Have not tried my gh4, gh5 and AF100 yet
Thanks !
Rod
mjgraves
#2 Posted: : Thursday, June 6, 2019 8:46:50 AM(UTC)
mjgraves
Have no such issues here. Just ran through an extensive test with various webcams, including:
  • Logitech C920
  • Logitech C922
  • Logitech C930e
  • Logitech Brio 4K
  • Logitech BCC950 PTZ
  • Logitech Rally PTZ
Was documenting issues with NDI Scan Convertor and NDI Connect Free for a Newtek support ticket.
Teye
#3 Posted : Thursday, June 6, 2019 9:04:29 AM(UTC)
Teye
Are you using windows 10 ?
#4 Posted : Thursday, June 6, 2019 12:15:02 PM(UTC)
Was thanked: 4644 time(s) in 1605 post(s)
There have been no updates to the camera input functionality at all since .58.
Only thing I can think of is maybe since the virus scanner or windows defender was scanning the update for a while
causing the system to reduce in performance temporarily.
Or possibly the setting was disabled to use the NVIDIA graphics in vMix, so check that again in the NVIDIA Control Panel.
Teye
#5 Posted : Friday, June 7, 2019 7:05:59 AM(UTC)
Teye
Thank you Martin.
I believe I have check those things but will take another look.
The topic of my post was wrong....it should have said all is working fine with version 21.53 (the last update to version 21).
I have been a user since version 17 and have never had a single problem.
mjgraves
#6 Posted : Saturday, June 8, 2019 1:13:31 AM(UTC)
mjgraves
Yes, Windows 10 Pro.
vMix 22.0.0.60
Compulab Airtop-PC
- i7-5775C CPU
- 16 GB RAM
- GTX 750 Ti GPU
- Corsair M.2 SATA disk
#7 Posted : Saturday, June 8, 2019 10:27:32 PM(UTC)
Try adding the webcams at a lower resolution (such as 640x480 or 1280x720). If they are jittery it is likely
they are being used at a higher resolution in vMix now which may be consuming all the available USB bandwidth.
Florent13
#8 Posted : Thursday, February 27, 2020 3:18:43 PM(UTC)
Florent13
Do you have a video demonstration with the Logitech brio 4K camera?
mjgraves
#9 Posted : Friday, February 28, 2020 1:29:58 AM(UTC)
mjgraves
Originally Posted by: Florent13 Go to Quoted Post
There are dozens of such videos on YouTube: https://www.youtube.com/...arch_query=logitech+brio
Guest (4)
