VMIX 22.60 not working with web cams ... vmix 21.58 is fine
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Hi All,
Just installed vmix 22 and none of my webcams are working properly. the inputs are jittery and flicker a little. system is loafing along.
reinstalled vmix 21.58 and all is well. Webcams work fine with other apps too.
my system: acer aspire V 15 Nitro
OS: windows 10 home latest updates Video card: Nvidia 945m CPU: I7 6500U RAM: 8 gigs ddr4 webcams: c920, c930e and builtin cam
Have not tried my gh4, gh5 and AF100 yet
Thanks !
Rod
Have no such issues here. Just ran through an extensive test with various webcams, including:
- Logitech C920
- Logitech C922
- Logitech C930e
- Logitech Brio 4K
- Logitech BCC950 PTZ
- Logitech Rally PTZ
Was documenting issues with NDI Scan Convertor and NDI Connect Free for a Newtek support ticket.
Are you using windows 10 ?
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
There have been no updates to the camera input functionality at all since .58. Only thing I can think of is maybe since the virus scanner or windows defender was scanning the update for a while causing the system to reduce in performance temporarily.
Or possibly the setting was disabled to use the NVIDIA graphics in vMix, so check that again in the NVIDIA Control Panel.
Martin vMix
Thank you Martin.
I believe I have check those things but will take another look. The topic of my post was wrong....it should have said all is working fine with version 21.53 (the last update to version 21). I have been a user since version 17 and have never had a single problem.
Originally Posted by: Teye  Are you using windows 10 ? Yes, Windows 10 Pro. vMix 22.0.0.60 Compulab Airtop-PC - i7-5775C CPU - 16 GB RAM - GTX 750 Ti GPU - Corsair M.2 SATA disk
Try adding the webcams at a lower resolution (such as 640x480 or 1280x720). If they are jittery it is likely they are being used at a higher resolution in vMix now which may be consuming all the available USB bandwidth.
Joined: 2/21/2020(UTC) Posts: 7   Location: Marseille 6ème Thanks: 1 times
Hello, Do you have a video demonstration with the Logitech brio 4K camera?
