Curtis Martin
#1 Posted : Monday, June 3, 2019 11:13:21 PM(UTC)
Curtis Martin
I'm using data to add a licensing number at the end of a song title via a data source. I need 4 spaces between end of the song title and the licensing number. For Example "Song Title 123456". Even though "Song Title _ _ _ _ 123456" (underscore represent spaces) is in the data cell, the graphic returns "Song Title_123456", thus removing 3 of the 4 spaces.
I tried concatenating the song title + 4 spaces + licensing numbers into a separate cell and then using that cell, but it still removes the extra spaces.
Any ideas on what causes this or how to format a line in GT title designer that simply tags on a license string that includes the spaces and the number after the data driven song title?
EDIT: It must be a common to html or something, because after I posted this, simply typing in spaces with the space bar in my example, it removed my spaces in this very post on this forum. I have gone back and inserted underscores to represent the spaces.
#2 Posted : Monday, June 3, 2019 11:19:22 PM(UTC)
Was thanked: 1008 time(s) in 830 post(s)
what type of datasource file ?
from a csv for example it does not remove extra spaces in between
FYI i dont see extra spaces in your post.
Curtis Martin
#3 Posted : Monday, June 3, 2019 11:22:43 PM(UTC)
Curtis Martin
It was a csv file created in Open Office.
I updated my original post to reflect exactly what you observed:No spaces between song and number...even in this post. Something crazy going on.
#4 Posted : Monday, June 3, 2019 11:31:12 PM(UTC)
Not a vMix issue then
have you checked the csv file in notepad for example ?
Curtis Martin on 6/4/2019(UTC)
rudyengels
#5 Posted : Monday, June 3, 2019 11:51:36 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Did you try a non-breaking space to see if that solves the issue?
In Open Office a non-breaking space is done via Control + Shift + Space
thanks 1 user thanked rudyengels for this useful post.
Curtis Martin
#6 Posted : Tuesday, June 4, 2019 12:09:36 AM(UTC)
Curtis Martin
Doggy and Rudy - Thanks for your help.
The non-breaking space did the trick. Interestingly, I realized I had been using a .ods (office spreadsheet) file, instead of a true CSV file. Resaving as a CSV remedied the problem as well. Must be an Open Office thing.
So kudos to both of you.
