Data Sources seems to be removing multiple spaces
Joined: 10/30/2018(UTC) Posts: 13  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I'm using data to add a licensing number at the end of a song title via a data source. I need 4 spaces between end of the song title and the licensing number. For Example "Song Title 123456". Even though "Song Title _ _ _ _ 123456" (underscore represent spaces) is in the data cell, the graphic returns "Song Title_123456", thus removing 3 of the 4 spaces.
I tried concatenating the song title + 4 spaces + licensing numbers into a separate cell and then using that cell, but it still removes the extra spaces.
Any ideas on what causes this or how to format a line in GT title designer that simply tags on a license string that includes the spaces and the number after the data driven song title?
EDIT: It must be a common to html or something, because after I posted this, simply typing in spaces with the space bar in my example, it removed my spaces in this very post on this forum. I have gone back and inserted underscores to represent the spaces.
what type of datasource file ? from a csv for example it does not remove extra spaces in between FYI i dont see extra spaces in your post.
It was a csv file created in Open Office.
I updated my original post to reflect exactly what you observed:No spaces between song and number...even in this post. Something crazy going on.
Not a vMix issue then
have you checked the csv file in notepad for example ?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Did you try a non-breaking space to see if that solves the issue?
In Open Office a non-breaking space is done via Control + Shift + Space
 1 user thanked rudyengels for this useful post.
Doggy and Rudy - Thanks for your help.
The non-breaking space did the trick. Interestingly, I realized I had been using a .ods (office spreadsheet) file, instead of a true CSV file. Resaving as a CSV remedied the problem as well. Must be an Open Office thing.
So kudos to both of you.
