Joined: 2/18/2019(UTC) Posts: 58  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hi from germany!
I am searching for a PC Hardware solution working with my Blackmagic Design ATEM Studio. The idea is to send some video signal over the HDMI OUT to a HDMI Input of the switcher, and receive the "Master" Video signal over a HD-SDI Input of the PC-Card. Then Vmix would have the job to stream and record.
The DeckLink HD Extreme 3D+ could be a solution, but does this card work with Vmix?
Thx Burie
Originally Posted by: burie  The DeckLink HD Extreme 3D+ could be a solution, but does this card work with Vmix? Yes, it works with vMix (shown below with v22, under Windows 10).  BMDExtreme.PNG (13kb) downloaded 3 time(s).
Originally Posted by: zenvideo  Originally Posted by: burie  The DeckLink HD Extreme 3D+ could be a solution, but does this card work with Vmix? Yes, it works with vMix (shown below with v22, under Windows 10). well, I will trust you :-) have bought one out of a Apple Computer. My personal problem is... I bought a card some time ago (not from BlackmagicDesign) and this card does not work with either Vmix or other software (Nagasoft et al.). That was a total flop. I hope this time it works better
The card I used for the screen grab above is one which I bought on ebay, and I think the owner said it had been in a Mac-based editing system, but I own a few other Blackmagic I/O devices so I already knew that the "Blackmagic Desktop Video" drivers work with vMix and quite a lot of other software.
Originally Posted by: zenvideo  The card I used for the screen grab above is one which I bought on ebay, and I think the owner said it had been in a Mac-based editing system, but I own a few other Blackmagic I/O devices so I already knew that the "Blackmagic Desktop Video" drivers work with vMix and quite a lot of other software. That might be right. The Extreme 3D is in the system and Vmix can see it. BUT the card has TWO SDI-Inputs AFAIK, so why does VMIX offer only one Input of the card?
Joined: 1/25/2019(UTC) Views messages in topic : 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
i have the same card in one of my pc's, it only acts as one channel card. input/output is possible to use as single link or dual link, that means you can have 3g oder stereophonic signals splitted in two hd signals. with casparCG or Newblue Titler, CHB out works as key out. without any option a normal HD signal should come out of A and B as the same, using the convert options in BM windows system control tool, CHB OUT is the converted output.
Originally Posted by: burie  The Extreme 3D is in the system and Vmix can see it. BUT the card has TWO SDI-Inputs AFAIK, so why does VMIX offer only one Input of the card? vMix will only see what the Blackmagic driver exposes to it. As mentioned, this card only has single channel recording/playback capability, despite the various physical I/O connections, so vMix only sees it as a single channel device.
