burie
#1 Posted : Monday, February 18, 2019 3:44:32 AM(UTC)
burie
Germany
Hi from germany!
I am searching for a PC Hardware solution working with my Blackmagic Design ATEM Studio. The idea is to send some video signal over the HDMI OUT to a HDMI Input of the switcher, and receive the "Master" Video signal over a HD-SDI Input of the PC-Card. Then Vmix would have the job to stream and record.
The DeckLink HD Extreme 3D+ could be a solution, but does this card work with Vmix?
Thx
Burie
zenvideo
#2 Posted : Monday, February 18, 2019 11:46:30 PM(UTC)
zenvideo
Yes, it works with vMix (shown below with v22, under Windows 10).
burie
#3 Posted : Saturday, February 23, 2019 2:21:37 AM(UTC)
burie
Germany
well, I will trust you :-) have bought one out of a Apple Computer.
My personal problem is... I bought a card some time ago (not from BlackmagicDesign) and this card does not work with either Vmix or other software (Nagasoft et al.). That was a total flop.
I hope this time it works better
zenvideo
#4 Posted : Saturday, February 23, 2019 2:31:08 AM(UTC)
zenvideo
The card I used for the screen grab above is one which I bought on ebay, and I think the owner said it had been in a Mac-based editing system, but I own a few other Blackmagic I/O devices so I already knew that the "Blackmagic Desktop Video" drivers work with vMix and quite a lot of other software.
burie
#5 Posted : Thursday, March 28, 2019 7:47:39 AM(UTC)
burie
Germany
That might be right. The Extreme 3D is in the system and Vmix can see it. BUT the card has TWO SDI-Inputs AFAIK, so why does VMIX offer only one Input of the card?
Peter1000
#6 Posted : Thursday, March 28, 2019 5:06:04 PM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
i have the same card in one of my pc's, it only acts as one channel card.
input/output is possible to use as single link or dual link, that means you can have 3g oder stereophonic signals splitted in two hd signals.
with casparCG or Newblue Titler, CHB out works as key out.
without any option a normal HD signal should come out of A and B as the same, using the convert options in BM windows system control tool, CHB OUT is the converted output.
zenvideo
#7 Posted : Thursday, March 28, 2019 6:16:02 PM(UTC)
zenvideo
vMix will only see what the Blackmagic driver exposes to it. As mentioned, this card only has single channel recording/playback capability, despite the various physical I/O connections, so vMix only sees it as a single channel device.
Similar Topics
Decklink HD Extreme 3D+ Support (Hardware Compatibility)
by nagendransm 6/7/2014 3:30:55 AM(UTC)
Blackmagic Decklink HD Extreme 3D+ SDI (General Discussion)
by GBIM 5/16/2014 10:13:55 PM(UTC)
