GT
Dynamicly change color (fill) of rectangle
Hi everyone, Is there a way to dynamically adjust the (fill) color of an object, like a rectangle? Previously our animations were made with .XML and code it from scratch. With GT we have the capabilities of designing it in GT, but we can't find a way to make it possible for a dynamic way of changing the content of a color code. In XML you could do it like this: Quote:<Retangle Fill="{Binding Text, ElementName=textfield}" ..... > The textfield in the above code line referred to a hidden textblock/field in which the color code was set. In this way we could change the color in Vmix like it was a normal textfield. With that possibility we can load content into the several textfields. We would gladly use the possibilities in GT, so does anyone know a solution for this issue? Thanks in advance for all your help!
one reason to keep the good old XAML titles ;-)
FYI, not an issue , merely an unavailable option (currently)
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
 1 user thanked Rinsky for this useful post.
Thanks for the quick responses. We will wait patiently.
We will keep using the (good) old XAML-templates.
GT
