rickvoskamp
#1 Posted : Tuesday, March 12, 2019 5:22:12 AM(UTC)
rickvoskamp
Is there a way to dynamically adjust the (fill) color of an object, like a rectangle?
Previously our animations were made with .XML and code it from scratch.
With GT we have the capabilities of designing it in GT, but we can't find a way to make it possible for a dynamic way of changing the content of a color code.
In XML you could do it like this:
<Retangle Fill="{Binding Text, ElementName=textfield}" ..... >
The textfield in the above code line referred to a hidden textblock/field in which the color code was set. In this way we could change the color in Vmix like it was a normal textfield.
With that possibility we can load content into the several textfields.
We would gladly use the possibilities in GT, so does anyone know a solution for this issue?
Thanks in advance for all your help!
#2 Posted : Tuesday, March 12, 2019 6:12:36 AM(UTC)
one reason to keep the good old XAML titles ;-)
FYI, not an issue , merely an unavailable option (currently)
Rinsky
#3 Posted : Tuesday, March 12, 2019 6:37:48 AM(UTC)
Rinsky
thanks 1 user thanked Rinsky for this useful post.
M4R3C on 4/28/2019(UTC)
rickvoskamp
#4 Posted : Tuesday, March 12, 2019 8:18:48 AM(UTC)
rickvoskamp
Thanks for the quick responses. We will wait patiently.
We will keep using the (good) old XAML-templates.
