Setting a shortcut for DataSource Next Row
Thanks: 11 times Was thanked: 7 time(s) in 4 post(s)
Still really enjoying the power of the new GT Title designer but.. I am now playing with changing colours (images)in a database, and I am having problems changing the data with a shortcut. This is a very simple test to swap the colours around, it works well when I go into the data source manager and select the different row but when I try doing it with a datasourcenextrow shortcut it doesn't change. Is my format incorrect for doing this in the shortcut, I am learning as I go along?  blackred1.png (31kb) downloaded 16 time(s). blackred2.png (41kb) downloaded 21 time(s).
Joined: 12/27/2012(UTC) Posts: 5,481  Location: Belgium Thanks: 314 times Was thanked: 1017 time(s) in 835 post(s)
A good idea is to check on a post you made on a FB page with the same question as an answer has been given there more than 3 hrs before this post
Originally Posted by: doggy  A good idea is to check on a post you made on a FB page with the same question as an answer has been given there more than 3 hrs before this post Ahh apologies, I did not get a notification that there was a reply on that post. So is this not what the DataSourceNextRow option is for I take it?
No, Is how you specify the settings for the shortcut and your goal
The value needs to be (Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1') and not a link to your file
Originally Posted by: doggy  The value needs to be (Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1') and not a link to your file And what would that be in this case if you don't mind me asking, how would vmix know where to access it if it is not a link to the file? I tried redblack.xls but same thing.
say you open an excel file as a data source , if you don't rename it it will be called "Excel/CSV" for your shortcut you choose for value the NAME of the data source which is "Excel/CSV"" as optional value one could add the sheet you are using of your file (if its an excel with multiple sheets ) being Sheet1 add a comma in between and you get 'Excel/CSV,Sheet1' for the needed value for your shortcut just as the help says Quote: (Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1')
Originally Posted by: doggy  say you open an excel file as a data source , if you don't rename it it will be called "Excel/CSV" for your shortcut you choose for value the NAME of the data source which is "Excel/CSV"" as optional value one could add the sheet you are using of your file (if its an excel with multiple sheets ) being Sheet1 add a comma in between and you get 'Excel/CSV,Sheet1' for the needed value for your shortcut just as the help says Quote: (Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1') Sorry I am just not getting anywhere, you mean physically enter those words, or the excel name..I have done both, nothing happens when I click the shortcut.  excel.png (46kb) downloaded 11 time(s).
Wait Wait Wait...I got this LOL That was like pulling teeth. You mean I actually have to go in and change the name from Excel/CSV to whatever, and then select the new name as the input :) Maybe I am a bit stupid on it, but that was not overly clear..at least not to me :)  quinton.png (29kb) downloaded 19 time(s).
You dont have to change the name but ofcourse if there are a few with the same name then guess what ;-)
