Quinton
#1 Posted : Wednesday, February 27, 2019 12:37:29 AM(UTC)
Quinton
Was thanked: 7 time(s) in 4 post(s)
Still really enjoying the power of the new GT Title designer but..
I am now playing with changing colours (images)in a database, and I am having problems changing the data with a shortcut.
This is a very simple test to swap the colours around, it works well when I go into the data source manager and select the different row but when I try doing it with a datasourcenextrow shortcut it doesn't change.
Is my format incorrect for doing this in the shortcut, I am learning as I go along?
#2 Posted : Wednesday, February 27, 2019 12:59:09 AM(UTC)
A good idea is to check on a post you made on a FB page with the same question as an answer has been given there more than 3 hrs before this post
Quinton
#3 Posted : Wednesday, February 27, 2019 1:40:58 AM(UTC)
Quinton
Ahh apologies, I did not get a notification that there was a reply on that post.
So is this not what the DataSourceNextRow option is for I take it?
#4 Posted : Wednesday, February 27, 2019 1:44:43 AM(UTC)
No, Is how you specify the settings for the shortcut and your goal
Quinton
#5 Posted : Wednesday, February 27, 2019 1:49:11 AM(UTC)
Quinton
I was looking at the manual for this, that's why I was using that option, but it didn't do anything..
https://www.vmix.com/hel...?DataSourcesControl.html
#6 Posted : Wednesday, February 27, 2019 3:42:04 AM(UTC)
The value needs to be (Name of the Data Source and Table Name (optional) eg 'Excel/CSV,Sheet1') and not a link to your file
adriancituli on 12/21/2020(UTC)
Quinton
#7 Posted : Wednesday, February 27, 2019 4:09:09 AM(UTC)
Quinton
And what would that be in this case if you don't mind me asking, how would vmix know where to access it if it is not a link to the file?
I tried redblack.xls but same thing.
#8 Posted : Wednesday, February 27, 2019 4:43:22 AM(UTC)
say you open an excel file as a data source , if you don't rename it it will be called "Excel/CSV"
for your shortcut you choose for value the NAME of the data source which is "Excel/CSV""
as optional value one could add the sheet you are using of your file (if its an excel with multiple sheets ) being Sheet1
add a comma in between and you get 'Excel/CSV,Sheet1' for the needed value for your shortcut just as the help says
Quinton
#9 Posted : Wednesday, February 27, 2019 5:17:47 AM(UTC)
Quinton
Sorry I am just not getting anywhere, you mean physically enter those words, or the excel name..I have done both, nothing happens when I click the shortcut.
Quinton
#10 Posted : Wednesday, February 27, 2019 5:32:40 AM(UTC)
Quinton
Wait Wait Wait...I got this LOL
That was like pulling teeth.
You mean I actually have to go in and change the name from Excel/CSV to whatever, and then select the new name as the input :)
Maybe I am a bit stupid on it, but that was not overly clear..at least not to me :)
#11 Posted : Wednesday, February 27, 2019 6:55:13 AM(UTC)
You dont have to change the name but ofcourse if there are a few with the same name then guess what ;-)
Quinton on 2/27/2019(UTC)
