2 Pages<12
Ernest Król
#21 Posted : Wednesday, September 25, 2013 11:06:39 AM(UTC)
Ernest Król
dundurs wrote:
9. When using Decklink capture (Decklink SDI), sometimes after using the input for some time we experience noticeable video delay (around 1sec). After Resetting the input, the problem goes away. It happens pretty randomly. Probably related to Decklink driver, but I just wanted to let you know just in case.
Dundurs
I confirm that. And i've noticed when connecting a camera (to computer, capture input added already in vmix) video from this camera is delayed about 1 (sometimes more) seconds.
Look at 2m50s (when dj turns to crowd)
http://www.dailymotion.c...ia-dj-edy-club-139_music
Isn't it "virtual genlock" issue?
#22 Posted : Wednesday, September 25, 2013 11:14:02 AM(UTC)
The Virtual GenLock in vMix has a maximum buffer size of 120ms PAL, 99ms NTSC.
vMix also reads frames from the camera as fast as they are given to prevent any possibility of delay.
(This assumes "Use VMR" is not ticked, as VMR adds its own delay and is only intended for diagnostic purposes)
This means the delay must be happening within the hardware or drivers, so a possible solution would be to check for the latest capture drivers?
jdrwor
#23 Posted : Thursday, September 26, 2013 4:24:15 PM(UTC)
jdrwor
There doesn't appear to be a Shortcut or API function to start or stop streaming. It would be great if that could be squeezed into the 10.1 release.
dundurs
#24 Posted : Friday, September 27, 2013 5:26:15 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
10. Just caused a very dangerous situation. We were streaming using FMLE and recording to SD card. SD card got filled up, vMix displayed error that there is no more space and stopped external, which is really not cool. Using version 10.0.0.59.
#25 Posted : Friday, September 27, 2013 5:35:59 AM(UTC)
Hi Dundurs,
Are you certain the external output stopped as well?
I just did a test where I was recording to file and streaming with external output.
When the disk space run out the streaming continued as per normal.
It might possibly be the issue described in the following thread:
http://forums.vmix.com.a....aspx?g=posts&t=1293
In which case a check of the yyyymmdd.xx.log files in documents\vmixstorage would be helpful.
dundurs
#26 Posted : Friday, September 27, 2013 6:06:01 AM(UTC)
dundurs
1. Yes, Im certain, that the External stopped by itself. vMix displayed error, FMLE current fps dropped to 10fps, audio was fine, video was frozen.
2. Actually SD card shows free space of 500 MB, which means it either lost contact with SD card reader or is faulty, which happens from time to time. So the issue might have been initiated by "sudden loss of recording media".
3. vMix log:
10.0.0.59 - RE - 2013.09.26. 12:18:09
vMix.VMIXException: There is not enough disk space to continue this recording.
at dp.zq(String a)
at nzzv.d()
4. Recording log:
2013.09.26. 10:09:52, Version: 10.0.0.59
2013.09.26. 10:09:52, Size: 720x576
2013.09.26. 10:09:52, System: PAL 50i or 25p
2013.09.26. 10:09:52, Codec: Microsoft MPEG-2 Encoder
2013.09.26. 10:09:52, AudioDevice: vMix Audio
2013.09.26. 10:09:52, AudioFormat: 44100 Hz 16 Bit 2 Channels
2013.09.26. 10:09:52, AudioDelay: 0
2013.09.26. 10:09:52, RestartInterval: 0
2013.09.26. 10:09:52, BitRate: 8
2013.09.26. 10:59:15, StartRecording
2013.09.26. 12:18:04, StopRecording
2013.09.26. 12:18:04, Duration: 01:18:48
2013.09.26. 12:18:04, Frames: 118193
2013.09.26. 12:18:04, DroppedFrames: 17
2013.09.26. 12:18:04, DueToSourceFrameRate: 17
2013.09.26. 12:18:04, DueToHardDiskOrCPU: 0
2013.09.26. 12:18:04, DroppedSamples: 18
2013.09.26. 12:18:04, MissedSamples: 0
2013.09.26. 12:18:04, SyncedSamples: 0
2013.09.26. 12:18:04, AudioOffset: 20
2013.09.26. 12:18:04, AudioDelay: 0
2013.09.26. 12:18:04, AudioEngine
2013.09.26. 12:18:04, Running: True
2013.09.26. 12:18:04, SampleRate: 44100hz 16 Bit
2013.09.26. 12:18:04, MixingErrors: 0
2013.09.26. 12:18:04, Streams
2013.09.26. 12:18:04, Stream0
2013.09.26. 12:18:04, Samples: 0
2013.09.26. 12:18:04, Dropped: 0
2013.09.26. 12:18:04, Latency: 0
2013.09.26. 12:18:04, Stream1
2013.09.26. 12:18:04, Samples: 399266
2013.09.26. 12:18:04, Dropped: 9
2013.09.26. 12:18:04, AudioInputs
2013.09.26. 12:18:04, Mana kamera
2013.09.26. 12:18:04, Latency: 150/80
2013.09.26. 12:18:04, Resampled: 98
#27 Posted : Friday, September 27, 2013 10:47:38 AM(UTC)
Dundurs,
It does sound like the freezing issue which has been fixed in the version of vMix 11 I am currently testing.
The following additional features and fixes will also be included:
* Interlaced Recording and Output under the following workflow:
a) Output Frame Rate set to 50p or 59.94p b) Capture Deinterlacing Set to "Bob" c) Recording set to 50i or 59.94i
This will work for AVI, MPEG-2 and MP4 recording formats
* Fixed title editor bug
* Overlays can already be removed with OverlayInputsAllOff function
* Input collapsed state is saved to preset
dundurs
#28 Posted : Friday, September 27, 2013 12:37:45 PM(UTC)
dundurs
Great improvements!
Just to clarify how the External stopped issue happened:
1. vMix displayed error about disk space
2. External button changed to Stopped state (not green)
3. FMLE current fps dropped to 10 fps
4. audio was ok, video froze
5. we stopped FMLE
6. we pressed External Start (went green)
7. we run FMLE
8. video ok, audio ok
Dundurs
thanks 1 user thanked dundurs for this useful post.
Adriankey4 on 9/29/2013(UTC)
Mauro Cesar
#29 Posted : Friday, September 27, 2013 6:27:26 PM(UTC)
Mauro Cesar
r@wisla wrote:
Mauro Cesar wrote:
There are many situations where I know the starting and ending point I want to use as a replay.
If this fits your needs a little, support this feature request http://forums.vmix.com.a....aspx?g=posts&t=1312
I did support your topic
Mauro
dundurs
#30 Posted : Saturday, September 28, 2013 6:20:48 AM(UTC)
dundurs
11. Any chance you could allow setting different vMix log path from recorded delay storage path? If the storage is out of space, then there will be no logs. Also we use ram disk for saving video delays for faster access and the ram disk gets cleaned up every time the computer is restarted.
Dundurs
jet
#31 Posted : Saturday, September 28, 2013 8:34:39 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
admin wrote:
The next release is going to take a bit longer as I am jumping directly to vMix 11.
The beta is a couple of weeks away and will include the following additional features:
* Support for Matrox MXO2 series
Hi Martin!
Do Matrox support mean that output thru Matrox is also possible? I hope so :)
Kind regards,
J. Tervo
#32 Posted : Thursday, October 3, 2013 10:54:13 AM(UTC)
vMix 11 Preview is now available:
http://forums.vmix.com.a....aspx?g=posts&m=6264
2 Pages<12
