AlanZ
#1 Posted : Thursday, January 10, 2019 11:39:25 AM(UTC)
AlanZ
I started playing with a Stream Deck Mini today with v22, and all was going well (including the cool use of thumbnails).
Then I shut down vMix. When I reopened vMix, it no longer recognizes the Stream Deck.
When I press keys on the deck, I get an alert triangle over the vMix logo.
I tried uninistalling the vMix app from the stream deck, but it never gets removed from the system;
I've also tried uninstalling the stream deck and uninstalling vMix... but so far, vMix and the deck still won't talk to each other.
So, and idea how to proceed?
Thanks!
AlanZ
#2 Posted: : Sunday, January 13, 2019 3:01:51 AM(UTC)
AlanZ
Anyone have an insight into how I can get the stream deck working again?
grinsekatz01
#3 Posted : Sunday, January 13, 2019 9:20:22 AM(UTC)
grinsekatz01
Austria
same problem here...
#4 Posted : Sunday, January 13, 2019 12:36:49 PM(UTC)
Was thanked: 4644 time(s) in 1605 post(s)
Does it work again after restarting the computer?
Also, note that when deleting/adding plugin assignments to buttons again, the shortcuts need to be updated with
the new buttons, as existing shortcuts will be assigned to the old ones.
Check the logs in Documents\vMixStorage\logs to see if there are any StreamDeck related errors.
If not, drop an email to info@vmix.com.au so we can investigate further.
#5 Posted : Sunday, January 13, 2019 3:57:57 PM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
Same problem
#6 Posted : Sunday, January 13, 2019 5:06:25 PM(UTC)
doggy,
See my previous post so we can diagnose what is happening.
#7 Posted : Sunday, January 13, 2019 5:18:16 PM(UTC)
Originally Posted by: admin Go to Quoted Post
doggy,
Yes and all it says is that the streamdeck is enabled
BUT i might have found an issue
It was not responding to the vMix Key when oe of the custom functions of the streamdeck was added (Clock / CPU)
after removing them and unplugging/pluggin in end restarting vMix the streamdeck it seems all fine again
#8 Posted : Sunday, January 13, 2019 5:22:52 PM(UTC)
oops spoke to soon
noticed when i added a vMix shortcut when vMix was not running it would not respond again after starting vMix
adding the shortcut while vMix running did the trick (after removing it first before starting vMix)
fingers crossed and hope this helps
EDIT: ok its not consistent , its a hit and miss
rnhturner
#9 Posted : Tuesday, January 15, 2019 4:35:07 AM(UTC)
rnhturner
Having the same issue. I am on vmix22....38
Waxmann
#10 Posted : Tuesday, January 15, 2019 10:16:19 PM(UTC)
Waxmann
Germany
same problem
#11 Posted : Tuesday, January 15, 2019 10:52:10 PM(UTC)
Hi all,
Just letting you know we have found a bug that occurs when connecting to the Stream Deck in some situations.
A vMix 22 beta update will likely be released tomorrow to address this.
doggy on 1/15/2019(UTC), grinsekatz01 on 1/16/2019(UTC)
#12 Posted : Wednesday, January 16, 2019 12:09:26 PM(UTC)
Just posted the update here:
https://forums.vmix.com/...eview-Released#post61288
Would be interested in hearing feedback on if this resolves the issues reported in this thread.
You may need to click Find again on each shortcut in vMix to detect the new button assignments and save them.
#13 Posted : Wednesday, January 16, 2019 6:35:32 PM(UTC)
So far its looking good
Activators: = super
- 2 color option possible ? for "OFF" state
- Would there be a possibility to add an on/off image ? not a must as one can set text but could be nice
#14 Posted : Wednesday, January 16, 2019 7:00:37 PM(UTC)
exported/imported Streamdeck profiles do not respond anymore without complete reconfiguring the keys
grinsekatz01
#15 Posted : Thursday, January 17, 2019 4:17:52 AM(UTC)
grinsekatz01
Austria
Good job!! After testing about 2,5 hours with 22.0.0.42, Stream Deck seems to do its job now reliable. No fails in communication, no loosing of shortcuts or activators. Connecting the Stream Deck - only works if the Stream Deck App has been started before vMix and the Deck is already plugged in. Activators are a great benefit, thanks for that.
I will use the Stream Deck also for PTZ-controll so it will be very helpful, if something like a PTZ-motionspeed shortcut can be added.
Greets
Guest (5)
