Hardware Compatibility
Turn off range of X-Keys lights?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
I am using activators with an X-Keys 24 to change the color of a button when inputs are in the output window. Is there a way to turn off a range of buttons (the buttons I don't want the user to press) I see where I can change the color for a range using the Default activator, but don't see a way of turning off the lights.
you're close! In the "Type" where you'd normally select XKEYS Button, Select "off"
Thanks, I will give that a try
