AlanZ
#1 Posted : Wednesday, November 21, 2018 8:53:31 AM(UTC)
AlanZ
I am using activators with an X-Keys 24 to change the color of a button when inputs are in the output window.
Is there a way to turn off a range of buttons (the buttons I don't want the user to press)
I see where I can change the color for a range using the Default activator, but don't see a way of turning off the lights.
AlanZ
#2 Posted : Friday, November 23, 2018 2:12:57 PM(UTC)
AlanZ
Anyone?
spencerm24
#3 Posted : Sunday, November 25, 2018 3:44:22 AM(UTC)
spencerm24
you're close! In the "Type" where you'd normally select XKEYS Button, Select "off"
AlanZ
#4 Posted : Sunday, November 25, 2018 4:31:17 AM(UTC)
AlanZ
Thanks, I will give that a try
Guest (4)
