Instant Replay
Instant Replay Shortcut
I'm currently editing a shortcut to enable me to change the replay time event to a custom time rather than the set -5, -10 & -20 seconds but when I change the "value" in seconds, the lowest number of seconds I can get is 6 seconds with the "value" box of the shortcut set at 1.
I've tried entering .5 etc but this does not work.
Anyone out there got a solution PLEASE.
Windows 10 vMix Pro JL Cooper ES-SloMo controller
Originally Posted by: JAG Media  I'm currently editing a shortcut to enable me to change the replay time event to a custom time rather than the set -5, -10 & -20 seconds but when I change the "value" in seconds, the lowest number of seconds I can get is 6 seconds with the "value" box of the shortcut set at 1.
Windows 10 vMix Pro JL Cooper ES-SloMo controller Check your replay settings, it may be set to add a few seconds to the beginning or end of the replay. If it was set to 3 on each end, you would only see a 6 second replay at the lowest. To confirm this, try going up to 10 seconds, if it creates a 16 second clip, that is your issue.
Thanks spencerm24 that's the problem solved, never thought to look there. It's simple when you know how :)
Instant Replay
