JAG Media
#1 Posted : Thursday, November 8, 2018 11:33:18 PM(UTC)
JAG Media
I'm currently editing a shortcut to enable me to change the replay time event to a custom time rather than the set -5, -10 & -20 seconds but when I change the "value" in seconds, the lowest number of seconds I can get is 6 seconds with the "value" box of the shortcut set at 1.
I've tried entering .5 etc but this does not work.
Anyone out there got a solution PLEASE.
Windows 10
vMix Pro
JL Cooper ES-SloMo controller
spencerm24
#2 Posted : Friday, November 9, 2018 2:31:42 AM(UTC)
spencerm24
Windows 10
vMix Pro
Check your replay settings, it may be set to add a few seconds to the beginning or end of the replay. If it was set to 3 on each end, you would only see a 6 second replay at the lowest. To confirm this, try going up to 10 seconds, if it creates a 16 second clip, that is your issue.
JAG Media
#3 Posted : Friday, November 9, 2018 3:52:47 AM(UTC)
JAG Media
Thanks spencerm24 that's the problem solved, never thought to look there. It's simple when you know how :)
Similar Topics
vMix 24 Instant Replay shortcuts (Feature Requests)
by MarkNF82 2/7/2021 4:42:08 AM(UTC)
Instant Replay shortcuts issues and questions (Instant Replay)
by Rinsky 3/1/2018 3:48:47 PM(UTC)
Additional Instant Replay Shortcuts (Feature Requests)
by DeeJay 10/2/2015 2:29:17 PM(UTC)
