Originally Posted by: rowby  Also, the word “Close” is a bad title for that button. It's a good point, and I agree. Altough "Del" might be better (than "Delete"), giving some spare room for potentially another button... Originally Posted by: BETech  The “Settings” menu is the simple, easy and logical choice. I sort of disagree. The only reason for having it in the Settings window is to free up space (for potentially other button/s) on the Input. And if in the Settings window, then the button must be named "Delete", as "Close" can easily be confused with closing the Window.
 1 user thanked richardgatarski for this useful post.
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
+1 for a remove input option like BETech suggests. The current close button is really on a dangerous place.
 1 user thanked Ronald555 for this useful post.
+1
There absolutely needs to be a confirmation before an input is closed. It has always caused issues on productions specially when the user isn't skilled.
+1 om Confirmation pop-up
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
+1 for removal of close button. My opinion is that right click menu on input should have remove option.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 again, couldn't for the life of me figure out what had be deleted or when and had to restart the project. The Other thing is it takes a while to realise it's that an not something just bugging out that needs bring in again etc
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
The lock button stops one from accidentally (or intentionally for that matter) closing out an input.
Located in the lower right near the hamburger menu and Overlay settings
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Originally Posted by: avsoundguy  The lock button stops one from accidentally (or intentionally for that matter) closing out an input.
Located in the lower right near the hamburger menu and Overlay settings True. But still the Close button user interface needs to be fixed, based on the real life experiences reported in this feature request.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
+1 for input closing confirmation
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
It looks like this has been added in vMix22. You can find it in the "Settings" / "Options" / "Display confirmation for Input Close button" checkbox. When you close an input you will get a red banner requesting Yes/No confirmation.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Originally Posted by: raugert  It looks like this has been added in vMix22. You can find it in the "Settings" / "Options" / "Display confirmation for Input Close button" checkbox. When you close an input you will get a red banner requesting Yes/No confirmation. Indeed, the option has been added in vMix 22
