Joeboe
#1 Posted : Friday, October 5, 2018 12:41:33 AM(UTC)
Joeboe
Hi all, I have a Blackmagic Desklink Duo, it is seen by vMix, but when I connect my cameras, it does not show them ...all I get is a black screen....Is there a way to set up this card to work in vmix, that I am not aware of...Thanks
stevespaw
#2 Posted : Friday, October 5, 2018 1:25:38 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
We will need a lot more info, resolution, framerate etc.
People use this card everyday, it is something with your source setup.
Steve
Reinaldo
#3 Posted : Wednesday, October 17, 2018 8:54:06 PM(UTC)
Reinaldo
Brazil
See if BlackMagic Desktop Video Setup is "seeing" the board.
Update to Last Desktop Video Setup version. Now is 10.11.2
markleman
#4 Posted : Wednesday, November 7, 2018 3:01:10 AM(UTC)
markleman
I have a 'Deck link duo 2' and had great problem when we first used it. I had to disable audio on the video input to get any video.
See https://forums.vmix.com/...-working-in-vmix--Solved
Other things that caught me out was the order of the inputs (1-3-2-4) and later I also had problems when I tried 720p25 and it just ignores it, where as 720p50 works fine. I find it frustrating that there is not a utility from black magic that gives you stats you about the SDI inputs (frequency, resolution, is it actually receiving anything etc). Hopefully someone will point one out ;-)
Hope you find your issue.
Mark Leman
Similar Topics
Blackmagic Duo 2 Audio is choppy after more than one input (Hardware Compatibility)
by willenglishiv 6/19/2023 9:24:28 AM(UTC)
VMix y Blackmagic Duo 2 (Hardware Compatibility)
by dolfi 3/28/2018 11:40:36 AM(UTC)
Blackmagic Duo 2 no video output (General Discussion)
by Studio279 6/1/2016 3:48:31 PM(UTC)
