Hi all, I have a Blackmagic Desklink Duo, it is seen by vMix, but when I connect my cameras, it does not show them ...all I get is a black screen....Is there a way to set up this card to work in vmix, that I am not aware of...Thanks
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: Joeboe  Hi all, I have a Blackmagic Desklink Duo, it is seen by vMix, but when I connect my cameras, it does not show them ...all I get is a black screen....Is there a way to set up this card to work in vmix, that I am not aware of...Thanks We will need a lot more info, resolution, framerate etc. People use this card everyday, it is something with your source setup. Steve
Joined: 5/24/2014(UTC) Posts: 46   Location: Brazil Thanks: 54 times Was thanked: 5 time(s) in 3 post(s)
See if BlackMagic Desktop Video Setup is "seeing" the board. Update to Last Desktop Video Setup version. Now is 10.11.2
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: Joeboe  Hi all, I have a Blackmagic Desklink Duo, it is seen by vMix, but when I connect my cameras, it does not show them ...all I get is a black screen....Is there a way to set up this card to work in vmix, that I am not aware of...Thanks I have a 'Deck link duo 2' and had great problem when we first used it. I had to disable audio on the video input to get any video. See https://forums.vmix.com/...-working-in-vmix--Solved Other things that caught me out was the order of the inputs (1-3-2-4) and later I also had problems when I tried 720p25 and it just ignores it, where as 720p50 works fine. I find it frustrating that there is not a utility from black magic that gives you stats you about the SDI inputs (frequency, resolution, is it actually receiving anything etc). Hopefully someone will point one out ;-) Hope you find your issue. Regards, Mark Leman
