#1 Posted : Wednesday, September 26, 2018 8:52:02 AM(UTC)
and available for download
https://www.newtek.com/ndi/
Guillaume
rowby on 12/1/2018(UTC)
mavik
#2 Posted : Wednesday, September 26, 2018 4:46:58 PM(UTC)
mavik
Thanks for the notice
spino
#3 Posted : Thursday, September 27, 2018 10:50:16 AM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
I have installed the last version of NDI tools (NDI Tools 3.7) but I have a problem with virtual camera: it says that I need Microsoft Security Avisory 3033929 but it's already installed in my PC (windows 7). Has anyone else experienced this problem?
Thank you in advance.
carsco
#4 Posted : Tuesday, November 27, 2018 12:33:32 AM(UTC)
carsco
Italy
It's an old issue without solution.
NEVER found.
I use an older version.
#5 Posted : Tuesday, November 27, 2018 5:27:32 AM(UTC)
Hey Spino
I'm not 100% sure but I think I read somewhere that some of the NDI Tools now require Windows 8 or higher.
Anyway you should report this on Newtek's NDI forum or Newtek support for more accurate information.
Guillaume
kane
#6 Posted : Tuesday, November 27, 2018 11:24:49 AM(UTC)
kane
Not all parts of NDI Tools requires Windows 8 or higher, just NDI Scan Converter has this requirement. All of the other parts should operate on Windows 7.
Kane Peterson
NewTek
spino
#7 Posted : Tuesday, November 27, 2018 11:14:31 PM(UTC)
spino
Italy
Hey Spino
Guillaume
Hi Guillaume, just an update. I installed Windows 10 and now my problem is solved. Cause Newtek says that just scan converter needs windows 10, I suppose there is something wrong in the code of virtual camera.
