NDI
NDI Tools 3.7 and NDI SDK 3.7 released
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I have installed the last version of NDI tools (NDI Tools 3.7) but I have a problem with virtual camera: it says that I need Microsoft Security Avisory 3033929 but it's already installed in my PC (windows 7). Has anyone else experienced this problem? Thank you in advance.
Joined: 11/26/2018(UTC) Posts: 29  Location: Rome Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
It's an old issue without solution. NEVER found.
I use an older version.
Quote:I have installed the last version of NDI tools (NDI Tools 3.7) but I have a problem with virtual camera: it says that I need Microsoft Security Avisory 3033929 but it's already installed in my PC (windows 7). Has anyone else experienced this problem? Thank you in advance. Hey Spino I'm not 100% sure but I think I read somewhere that some of the NDI Tools now require Windows 8 or higher. Anyway you should report this on Newtek's NDI forum or Newtek support for more accurate information. Guillaume
Not all parts of NDI Tools requires Windows 8 or higher, just NDI Scan Converter has this requirement. All of the other parts should operate on Windows 7.
Kane Peterson NewTek
Originally Posted by: DWAM  Quote:I have installed the last version of NDI tools (NDI Tools 3.7) but I have a problem with virtual camera: it says that I need Microsoft Security Avisory 3033929 but it's already installed in my PC (windows 7). Has anyone else experienced this problem? Thank you in advance. Hey Spino I'm not 100% sure but I think I read somewhere that some of the NDI Tools now require Windows 8 or higher. Anyway you should report this on Newtek's NDI forum or Newtek support for more accurate information. Guillaume Hi Guillaume, just an update. I installed Windows 10 and now my problem is solved. Cause Newtek says that just scan converter needs windows 10, I suppose there is something wrong in the code of virtual camera.
NDI
