NDI
Shortcuts and NDI commands
Thanks: 3 times Was thanked: 10 time(s) in 10 post(s)
I've had a hunt around and can't find an answer to this ...
If I create a trigger in an Input, and select the NDI Command function, a box appears for me to input the NDI Commend, eg AnimateIn1 or AnimateOut1 (in the case of Titler Live).
If I try to do the same thing as a shortcut, no box appears for me to enter the NDI command. However there is a message telling me that the shortcut will run the specified NDI command which I don't seem to be able to specify.
Anyone know what I'm missing?
Many thanks.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
That's not what I mean. I know what NDI commands I want to use. My point is there is nowhere to enter the command on the shortcut dialog when I select NDI command as the function. To clarify:
click the Settings button, click on Shortcuts, click Add, choose NDI command in the function drop down, and quick as a flash, no text box appears to enter the command.
??? DWAM attached the following image(s):  ndicommand.jpg (55kb) downloaded 59 time(s).You cannot view/download attachments. Try to login or register.
Thanks for this Guillaume. This looks like a bug. Would you mind having a look to see if you get the same result? If I create a new shortcut and select NDICommand as the function, I do get the screen you have shown there. If I edit a pre-existing shortcut and change the function to NDICommand from something else, this is what I get: w14 attached the following image(s):  vmix-1.JPG (49kb) downloaded 45 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
With AnimateIn and AnimateInOut we find we have to hop between the two to keep it active.
Our set up is AnimateIn1 and then TitlerLive puts up a title with a set duration, 8secs, and animates off
sometimes it doesn't animate off so you have to do AnimateInOut and that works for a bit, once that stops reacting we go back to AnimateIn and the TitlerLive out animation will work again.
Are you using a version of vmix from before NDI commands were introduced? are you fully up to date on upgrades?
NDI
