w14
#1 Posted : Wednesday, September 19, 2018 12:19:56 PM(UTC)
w14
I've had a hunt around and can't find an answer to this ...
If I create a trigger in an Input, and select the NDI Command function, a box appears for me to input the NDI Commend, eg AnimateIn1 or AnimateOut1 (in the case of Titler Live).
If I try to do the same thing as a shortcut, no box appears for me to enter the NDI command. However there is a message telling me that the shortcut will run the specified NDI command which I don't seem to be able to specify.
Anyone know what I'm missing?
Many thanks.
#2 Posted : Wednesday, September 19, 2018 12:25:02 PM(UTC)
Checking the reference documentation for using commands I believe ;o)
NDICommand syntax is fully documented
https://www.vmix.com/hel...utFunctionReference.html
Guillaume
w14
#3 Posted : Wednesday, September 19, 2018 12:46:22 PM(UTC)
w14
That's not what I mean. I know what NDI commands I want to use. My point is there is nowhere to enter the command on the shortcut dialog when I select NDI command as the function. To clarify:
click the Settings button, click on Shortcuts, click Add, choose NDI command in the function drop down, and quick as a flash, no text box appears to enter the command.
#4 Posted : Wednesday, September 19, 2018 5:04:27 PM(UTC)
DWAM attached the following image(s):
w14
#5 Posted : Thursday, September 20, 2018 4:10:40 AM(UTC)
w14
Thanks for this Guillaume. This looks like a bug. Would you mind having a look to see if you get the same result?
If I create a new shortcut and select NDICommand as the function, I do get the screen you have shown there.
If I edit a pre-existing shortcut and change the function to NDICommand from something else, this is what I get:
w14 attached the following image(s):
Barney Box Lane
#6 Posted : Thursday, September 20, 2018 7:31:04 AM(UTC)
Barney Box Lane
With AnimateIn and AnimateInOut we find we have to hop between the two to keep it active.
Our set up is AnimateIn1 and then TitlerLive puts up a title with a set duration, 8secs, and animates off
sometimes it doesn't animate off so you have to do AnimateInOut and that works for a bit, once that stops reacting we go back to AnimateIn and the TitlerLive out animation will work again.
Barney Box Lane
#7 Posted : Thursday, September 20, 2018 7:33:39 AM(UTC)
Barney Box Lane
Are you using a version of vmix from before NDI commands were introduced? are you fully up to date on upgrades?
