iamralphsutton
#1 Posted : Sunday, July 29, 2018 10:27:50 AM(UTC)
iamralphsutton
My on air light is connected to my WINK. home automation system -
and I use my android to turn it on when I am about to record.
I am wondering - is there any way - to have a trigger somehow turn the on-air light from vmix?
I realize it might be a dream - but I'd love it if the RECORD somehow triggered the on-air light?
the light is a leviton - if that helps.
Any thoughts on this?
Vuurmannetje
#2 Posted : Sunday, July 29, 2018 10:30:42 AM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
I dont know how WINK works, but you can have Vmix send a Midi signal to any Midi device. Can trigger it by almost anything including Stream being active.
Personally I use rtpMidi for midi over network into a controller to give me control and visual feedback (2 way connection).
So if theres a way to get midi into your system, then yeah, definitly possible.
Barney Box Lane
#3 Posted : Sunday, July 29, 2018 12:58:53 PM(UTC)
Barney Box Lane
yes IFTTT will do it, you could effectively get vmix to switch on a coffee machine when you go live (maybe with a half an hour delay too)
iamralphsutton
#4 Posted : Sunday, July 29, 2018 1:00:28 PM(UTC)
iamralphsutton
How does vmix trigger iftt?
Barney Box Lane
#5 Posted : Sunday, July 29, 2018 2:09:13 PM(UTC)
Barney Box Lane
I've never figured it out but the components are definitely there and I think it would involve using sheets and I think you can get vmix to fill in a data source using a shortcut but you'll see loads of weird stuff you can do it's very hard to navigate without knowing what all the apps and ingredients do first
ovinas
#6 Posted : Saturday, August 4, 2018 12:51:23 PM(UTC)
ovinas
I played a little bit...
https://ovinas.de/blog/
TuesdaysLive
#7 Posted : Saturday, August 4, 2018 2:54:46 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
One possibility would be to create a script file that writes, or places, a file (contents of file is irrelevant) into a Google Drive folder. Then have IFTTT use the "New file in your folder" trigger to affect the action to turn on your light.
#8 Posted : Saturday, August 4, 2018 5:54:36 PM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
perfect ;-)
stigaard
#9 Posted : Monday, August 6, 2018 8:48:57 AM(UTC)
stigaard
Denmark
X-keys have products for this exact functionality.
See Dan Slider from P.I. Engineering talking about it in the StreamFest Live show:
?t=27m27s
Can be bought at www.xkeys.com
