Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
My on air light is connected to my WINK. home automation system -
and I use my android to turn it on when I am about to record.
I am wondering - is there any way - to have a trigger somehow turn the on-air light from vmix?
I realize it might be a dream - but I'd love it if the RECORD somehow triggered the on-air light?
the light is a leviton - if that helps.
Any thoughts on this?
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
I dont know how WINK works, but you can have Vmix send a Midi signal to any Midi device. Can trigger it by almost anything including Stream being active. Personally I use rtpMidi for midi over network into a controller to give me control and visual feedback (2 way connection).
So if theres a way to get midi into your system, then yeah, definitly possible.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
yes IFTTT will do it, you could effectively get vmix to switch on a coffee machine when you go live (maybe with a half an hour delay too)
How does vmix trigger iftt?
I've never figured it out but the components are definitely there and I think it would involve using sheets and I think you can get vmix to fill in a data source using a shortcut but you'll see loads of weird stuff you can do it's very hard to navigate without knowing what all the apps and ingredients do first
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
One possibility would be to create a script file that writes, or places, a file (contents of file is irrelevant) into a Google Drive folder. Then have IFTTT use the "New file in your folder" trigger to affect the action to turn on your light.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Barney Box Lane wrote: you could effectively get vmix to switch on a coffee machine when you go live (maybe with a half an hour delay too) perfect ;-)
X-keys have products for this exact functionality. See Dan Slider from P.I. Engineering talking about it in the StreamFest Live show: ?t=27m27s Can be bought at www.xkeys.com
