TDfxclub
#1 Posted : Thursday, July 26, 2018 3:56:50 PM(UTC)
TDfxclub
Hello!
Since yesterday, I started to appear an error "D3DERR_INVALIDCALL: Invalid call (-2005530516)"
Today I completely reinstalled the operating system, installed all the new drivers - the problem did not disappear.
My comp:
win10 x64
Moth - Lenovo d20
CPU - 2cpus x5670
RAM - 32gb
GPU - 1050ti
What could be the problem?
stevespaw
#2 Posted : Friday, July 27, 2018 9:11:14 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Newest Nvidia drivers from Nvidia web site?
Steve
TDfxclub
#3 Posted : Friday, July 27, 2018 2:53:36 PM(UTC)
TDfxclub
Steve
Of course. This is the first thing I did
#4 Posted : Friday, July 27, 2018 10:03:24 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
This error is generally caused by another program on the computer interfering with the graphics card.
You can run the vMix Diagnostics utility in the start menu to locate the culprit and uninstall it.
babymike
#5 Posted : Sunday, October 28, 2018 2:00:02 AM(UTC)
babymike
Philippines
I'm getting the D3DERR_INVALIDCALL: Invalid call (-2005530516) error. After running vMix Diagnostics, the ff. results came out.
A background application that interferes with the graphics card has been detected.
One of the following applications may be the cause and it is recommended they be uninstalled or disabled:
GraphicOverlay: (C:\ProgramData\A-Volute\A-Volute.28054DF1F58B4\Modules\ScheduledModules\x64\NahimicOSD.dll)
SS3DevProps: (C:\ProgramData\A-Volute\A-Volute.SonicStudio3\Modules\ScheduledModules\x64\SS3DevProps.dll)
Intel HD Graphics Drivers for Windows(R): (C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_e2a368790e2879c5\igd9dxva64.dll)
SCAN COMPLETED WITH ERRORS
How do I uninstall or disable these DLL files? I tried manually deleting them but I was unsuccessful. Please help because vMix keeps on crashing.
zenvideo
#6 Posted : Sunday, October 28, 2018 2:53:17 AM(UTC)
zenvideo
Those two line may suggest a Nahimic audio driver which you could find listed under your "Apps & features". I had a problem with a Nahimic v1.x driver which was resolved by installing v2.3.21, although your problem may be different. I don't have an A-Volute folder in C:\ProgramData, so maybe you should be looking for something different, possibly with A-Volute or Sonic Studio in the name?
babymike
#7 Posted : Sunday, October 28, 2018 2:23:50 PM(UTC)
babymike
Philippines
Hello, i think i finally figured it out. After hours of looking for solutions to the problem, it looks like the answer is just under my nose. Since, i can't delete the NahimicOSD.dll and SS3DevProps.dll files, what i did was to move these files from their original file locations to the desktop. and guess what happened? by merely moving these files to the desktop, the problem is gone! No more conflict to the graphics card. I just hid the dll files (right-click, properties and tick hidden) to keep them out of my sight. I hope this works for other users who encountered the annoying D3DERR_INVALIDCALL: Invalid call (-2005530516) problem.
321actionvideo
#8 Posted : Tuesday, December 11, 2018 11:00:45 PM(UTC)
321actionvideo
I also moved the files to the desktop and resolved my issue temporarily, but they came back and had to do again. I also could not listen to headphones while sending master to hdmi output, so maybe need to uninstall the audio as well?
ErnestoMilla
#9 Posted : Friday, March 22, 2019 12:51:24 AM(UTC)
ErnestoMilla
Peru
Originally Posted by: TDfxclub Go to Quoted Post
Hello!
My comp:
win10 x64
Moth - Lenovo d20
CPU - 2cpus x5670
RAM - 32gb
GPU - 1050ti
HOLA yo tenia ese problema, al indagar era el Nahimic que me ocasionaba todo, buscando en foros, el Nahimic es solo un programa para mejorar el sonido, por lo que no dude en eliminar el programa, ahora el Vmix esta como nuevo, haciendo el scan me sale SIN PROBLEMAS.
ojala te sirva
321actionvideo
#10 Posted : Sunday, May 26, 2019 2:48:14 AM(UTC)
321actionvideo
So I have this error come up about once a month and just cut the files and move to desktop every time. This time I forgot to do a reboot and had some issues after that, so I need to know a long term solution to this problem. When I run the vmix system check I get the errors caused by
so can I uninstall the audio or need to update it?
#11 Posted : Sunday, May 26, 2019 12:08:11 PM(UTC)
Yes you will need to uninstall the software called "Nahimic" or "SonicStudio3".
It is not necessary for the operation of the computer and won't cause problems with audio if removed.
Sly
#12 Posted : Tuesday, July 21, 2020 4:35:51 PM(UTC)
Sly
I had been using vMix fine for the last month, now today every time I launch vMix it came up with this same D3DERR_INVALIDCALL error. I see that in over a year this unhandled error still hasn't been addressed. Note the "unhandled". Your code should be handling the error. As a developer myself, an unhandled error is an error in your code.
I have worked around this by uninstalling Nahimic, but that shouldn't be necessary.
#13 Posted : Tuesday, July 21, 2020 4:41:19 PM(UTC)
It is unhandled because Nahimic is hijacking vMix and injecting code.
We can't error handle code we didn't write, hence the error.
Similar Topics
D3DERR-Invalidcall: Invalid Call (-2005530516) (Instant Replay)
by Arlen 1/31/2024 5:29:00 AM(UTC)
