52 Pages«<34567>»
raugert
#81 Posted : Thursday, May 31, 2018 1:07:54 AM(UTC)
raugert
Canada
Thanks Ross,
That was the first thing I tried but it didn't seem to work. However, I just tried a different approach (URLEncode only the Value string rather than the whole Function string) and it seems to work !
I will test a little further and release a fix tomorrow. Getting late here :)
cheers,
Richard
TuesdaysLive
#82 Posted : Thursday, May 31, 2018 10:23:22 AM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
You may want to take another look into the "Save As" function, within the Mac version.
Utilizing 2.05b, I've been unable to save any panels using that selection. No dialog window opens. No indication of anything happening after selecting "Save As".
This is looking very good, however, and is proving to be a very good utility for vMix (both local and remote) operational control.
Rich
raugert
#83 Posted : Thursday, May 31, 2018 11:43:45 AM(UTC)
raugert
Canada
Hi Rich,
I can't seem to duplicate the 'SaveAs' issue you are having. What version of OSX are you using. Seems ok on 10.12.6.
I've made some updates as follows:
- Mathematical increments now work in XAML Titles
- added a confirmation dialog when quitting app
Updated version 2.0.6 in original post.
Thanks everyone for your contribution and your patience.
Richard
TuesdaysLive
#84 Posted : Thursday, May 31, 2018 11:48:25 AM(UTC)
TuesdaysLive
Oddly enough, I'm using 10.12.6 as well.
Doing additional testing...
The capability does work, until I attempted to 'clone' something when nothing was selected (if that makes sense).
Joeboe
#85 Posted : Thursday, May 31, 2018 12:14:00 PM(UTC)
Joeboe
It happens also with the windows version if I delete any element, (button, label, fader), but I found a work-around....I save every time I make a change, so that if something goes wrong, I can close and reopen the last saved .....so I will just have to continue from where I left off....it hurt me one day after I created a very nice GUI, only to find I had to start all over from the begining.......so now, I save after every action.....
thanks 1 user thanked Joeboe for this useful post.
TuesdaysLive on 5/31/2018(UTC)
TuesdaysLive
#86 Posted: : Thursday, May 31, 2018 2:46:05 PM(UTC)
TuesdaysLive
Joeboe -
You are absolutely correct. The same happens on the Mac version after deleting an item. Good catch.
Also noticed, after spending another hour creating a new template, that the simple 'Save' wasn't working either, even if the 'Save As' appeared to be operational.
Will do some additional digging to see if there may be an obvious cause.
raugert
#87 Posted : Saturday, June 2, 2018 12:18:17 PM(UTC)
raugert
Canada
update:
https://www.dropbox.com/...Builder%202.0.8.zip?dl=0
Let me know how it works.
appreciate you patience,
Richard
EDIT: Still has issues.. refer to next post for most recent
raugert
#88 Posted : Monday, June 4, 2018 1:38:29 AM(UTC)
raugert
Canada
Update: This version is the most stable so far. Fixed the issues with deleting objects and saving on Windows.
https://www.dropbox.com/...Builder%202.0.9.zip?dl=0
thanks 1 user thanked raugert for this useful post.
BETech on 6/4/2018(UTC)
mgrayeb
#89 Posted : Monday, June 4, 2018 8:06:56 AM(UTC)
mgrayeb
I'm trying to download this .exe file for Windows but keep getting a message from Dropbox that .exe files can't be previewed. I've tried to right-click on the .exe link and choose "Save As" but it only lets me save a .html file. I've tried to right click on the folder to save it but I can only save a Web page file.
I've tried with both Google Chrome and Firefox browsers. What am I doing wrong? Thank you.
raugert
#90 Posted : Monday, June 4, 2018 8:58:23 AM(UTC)
raugert
Canada
Download the complete vMix Panel Builder 2.0.9.zip file from Dropbox. Then unzip it once it is downloaded. It will create a Mac and a Windows folder. You can then move the folder for the platform you are using (I'm assuming windows in your case) to wherever you like. Run the 'vMix Panel Builder.exe' application from within the Windows folder. You may have to run the program as 'administrator' the first time, depending on your Windows setting.
Note: The 'Windows' folder contains the 'externals' required along with the program file so you must leave the folder intact. You can however create a shortcut to the program file if you like.
Hope that helps,
cheers,
Richard
Joeboe
#91 Posted : Monday, June 4, 2018 9:53:23 AM(UTC)
Joeboe
Thanks for the update.....Now, something I just noticed....When I go to close, I can not see the yes/no option in my layout....I wish it had remain like in the earlier version, where it appeared in the same area below the lock, as I had to expand my UI to see it...the same thing when I open Preferences...I have to expand my layout to see these windows, sometimes the same with the edit window, but since that is long, I see the edge, so I can pull it into view.....plus the preference and close option windows are locked in position....wish those could be free moving , same as the Edit window....other than that...2 thumbs up to this great program....
Joeboe
#92 Posted : Wednesday, June 6, 2018 12:20:19 PM(UTC)
Joeboe
Is there a way to change the Title in Builder Panel without having to go back to vMix....the scores are working great....now the changing of names...(Home..Away) to reflect in vMix...
Also, I found a bug that was never fixed from day one....when I select a button, and select Fullscreen, it never takes a colour...it just turns black...always did, but I forgot to mention it....I was making a new Interface when I kept getting this ....may be just in windows....
raugert
#93 Posted : Wednesday, June 6, 2018 6:23:56 PM(UTC)
raugert
Canada
Hi Joeboe:
To change a text in a Title .XAML is almost the same as changing the score Value except you simply enter the "new text" in the Value field
Command: SetText
SelectedName: the name of the text field in vMix (eg: Home)
Input: the name or input number in vMix
Value: the new text you wish to enter (eg: name of the Home team)
I'll look into the Fullscreen button turning black...
cheers,
Richard
Joeboe
#94 Posted : Wednesday, June 6, 2018 8:12:45 PM(UTC)
Joeboe
Yes, it works, but I have to use a button....What I was thinking about, is a special title Label where I can do those changes, rather than having to use a button, since I have to add the names on both button and in the text area...In UTC, all I do is add the name, and it shows up in vmix in real time, or change it in vMix, and it changes in UTC....but, it works, and that is the important thing
Video Dave
#95 Posted : Tuesday, June 12, 2018 1:02:50 AM(UTC)
Video Dave
We used 2.09 for two services today, worked like a charm. Yeah, the full screen button was black on start up, but as soon as I used it, it turned to the set color.
Richard thanks for keeping at it, to get it where it is today.
Dave
TuesdaysLive
#96 Posted : Tuesday, June 19, 2018 2:10:53 PM(UTC)
TuesdaysLive
Gotta say that after going through all the versions of this app, the latest version is working great in our production. Although I haven't created any new templates in a while, we used it for the first time, to fully operate our production, last week without any issues.
Well done!
spencerm24
#97 Posted : Monday, June 25, 2018 1:41:26 AM(UTC)
spencerm24
Is there a way to control the 3 streams independantly on this app? I'd like to have 3 buttons, one for each stream, that goes bright when its streaming to that one. I tried entering the value 1,2,3 but it doesn't behave right when I do that and its all 3 lit up when one is streaming.
raugert
#98 Posted : Monday, June 25, 2018 11:33:27 AM(UTC)
raugert
Canada
@spencerm24
The tally information for individual streams is not currently available in the vMIx API. It will report true if one or any stream is started. Therefor the tally will appear on any button with StartStopStreaming command. I will post a feature request with vMix.
spencerm24
#99 Posted : Monday, June 25, 2018 3:05:03 PM(UTC)
spencerm24
raugert wrote:
@spencerm24
Just checked the activators as well and it seems that there's no way to specify specific streams in that either. Would be nice to have xkeys or software like this indicate what is streaming.
MWilson
#100 Posted : Sunday, August 12, 2018 4:43:32 AM(UTC)
MWilson
Is this where we report bugs? Apologies if not.
When copying and pasting a fader, it copies only the background portion.
Then, the duplicate fader background can not be removed, and persists even when a new preset is created, the program must be restarted to get rid of it.
Windows 10 64-bit
Love the program so far by the way, great work.
Guest (13)
52 Pages«<34567>»
