Systems
What would you do?
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
I'm trying to decide weather to go a 3U rack based system with the specs below or a high end laptop version... thoughts? Also any help on a suitable cooling system for a rack based system that gets moved around a lot would be great! RACK SYSTEM: X299 DESIGNARE EX Intel Core i9 7920X GeForce GTX 1080 Ti 32GB RAM 2 x Samsung 960 EVO NVMe M.2 1TB SSD 2 x Blackmagic Design DeckLink 8K Pro 1 x Blackmagic Design DeckLink Mini Monitor 4K 1 x YUAN SC560N4 HDMI 850W PSU Cooling? 3U Case? LAPTOP SYSTEM: Aorus X9 DT - https://www.aorus.com/product-detail.php?p=748Sonnet Echo Express SE III 2 x Blackmagic Design DeckLink 8K Pro 1 x YUAN SC560N4 HDMI
Joined: 4/15/2018(UTC) Posts: 64  Location: Spain Thanks: 6 times Was thanked: 19 time(s) in 13 post(s)
850w is ok Water is better but air usually is ok too if well done
Check if you can use 2x nvme plus 5x pcie card. I think can not. Because some nvme share bandwith with pcie slot.
You can not compare this system with a laptop. All laptops has same basic problem, heat disiparion.
Regards
Jose.
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
Are you sure that a 3U system is high enough for a GTX 1080? I have 4U rack systems and it seems that 1U less wouldnt br high enough with all cables and that.
Rinsky wrote:Are you sure that a 3U system is high enough for a GTX 1080? I have 4U rack systems and it seems that 1U less wouldnt br high enough with all cables and that. I recently attempted this in a 3U case, and it was unsuccessful for exactly the reason you mentioned. 4U is as low as you can go for a 1080 GPU.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
It's true! 3U is too short to accommodate a 1080 GPU. My former employer built 4U and 5U systems, which had enough space for the taller PCIe boards. Larger cases also provide better airflow without resorting to the complexity of water cooling.
Does the Decklink 8k Pro support 4 sdi inputs?
Joined: 5/14/2018(UTC) Posts: 114 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
natzakaria wrote:Does the Decklink 8k Pro support 4 sdi inputs? The Decklink 8K is 4 bi-directional SDI connections in parallel.
 1 user thanked Vuurmannetje for this useful post.
Vuurmannetje wrote:natzakaria wrote:Does the Decklink 8k Pro support 4 sdi inputs? The Decklink 8K is 4 bi-directional SDI connections in parallel. Does that mean 2 inputs 2 outputs?
Hey there,
Did you go with the laptop or rack unit ?
I'm looking for reviews on the YUAN 4 HDMI card, did you experience any trouble with it ?
Systems
What would you do?
