Streaming error (Facebook Outage)
I keep this error
FFMPEG.Exited Streaming Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s rtmp://XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXxxxxxxxx: Input/output error ffmpeg started on 2018-05-13 at 18:50:07 Report written to "C:\ProgramData\vMix\streaming\streaming 20180513-185007.log" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 3729.556000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 768x576, 25 tbr, 10000k tbn, 25 tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [tcp @ 001f8c20] TCP Buffer has been set to 1490944 bytes rtmp:/XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX: Input/output error
I never see this error before. Any one know how to fix this?
Joined: 1/13/2010(UTC) Posts: 5,290  Location: Gold Coast, Australia Was thanked: 4645 time(s) in 1605 post(s)
This error usually means your stream key or url is no longer valid. Check with your streaming provider to see if it has changed. (This can happen quite often, especially with services like YouTube live)
I checked my url and key many times, and trust me , both url and key are correct.
In that case, the streaming provider should be able to check their logs to see why the stream is being rejected.
Martin vMix
I am getting the same error
Just with FB live, is there resolution?
ffmpeg started on 2018-05-13 at 08:33:52 Report written to "C:\ProgramData\vMix\streaming\streaming 20180513-083352.log" Command line: "C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 256M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v nvenc -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 2500k -g:v 120 -preset:v llhq -profile:v baseline -b:v 2500k -maxrate:v 2750k -codec:a libfaac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/20.0.0.55)" -f flv "rtmp:/xxxx.fme.ustream.tv/ustreamVideo/XXXX" -codec:v nvenc -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1500k -g:v 120 -preset:v llhq -profile:v baseline -b:v 1500k -maxrate:v 1650k -codec:a libfaac -b:a 96k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/20.0.0.55)" -f flv "rtmp://live-api.facebook.com:80/rtmp/XXXXX" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 414.079000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 59.94 tbr, 10000k tbn, 59.94 tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [tcp @ 060f8ac0] TCP Buffer has been set to 10560512 bytes [tcp @ 0613f500] TCP Buffer has been set to 10560512 bytes rtmp://live-api.facebook.com:80/rtmp/XXXXXX: Input/output error
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Very odd that I should get the same issue today, have been doing a 60 minute facebook show everyday for the past two years, and this is the first time things have failed - I am guessing a fecebook issue. Code:FFMPEG.Exited
Streaming
rtmp://live-api.facebook.com:80/rtmp/1946557935368821?a=xxxxxxxxxxxxxxxxx: Input/output error
ffmpeg started on 2018-05-13 at 14:59:50
Report written to "C:\ProgramData\vMix\streaming\streaming 20180513-145950.log"
Duration: N/A, start: 195273.399000, bitrate: 1536 kb/s
[tcp @ 00238760] TCP Buffer has been set to 998400 bytes
rtmp://live-api.facebook.com:80/rtmp/1946557935368821?a=xxxxxxxxxxxxxxxx: Input/output error
 1 user thanked kgoodyer for this useful post.
I have the same never seen "Stream has disconnected." "FFMEG.Exited", message, tried facebook "create live stream" browser generated stream key and used custom rtmp and a similar message. Can vMix look into please?
It does look like the Facebook Live servers are down at the moment with errors of being unable to stream regardless of the encoder. I suspect they may have an outage and will post an update if we know more (or if the issue resolves itself).
Martin vMix
I am having this issue as well. Looks like it just started today. Is there any work around?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:Is there any work around? Stream to a real streaming platform, FBLive is just a toy for selfie video
Rank: Guest
Groups: Guests
hi admin
exactly the same problem here, the error started today.
We are having the same issue. Although I am able to stream on Facebook using the web interface. Are we sure this is a Facebook outage? I cannot find anything online that indicates an outage with Facebook.
You have been a member since:: 5/13/2017(UTC) Posts: 111 Location: London
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
Me too, fwiw. Has to be a FB error.
FFMPEG.Exited Streaming Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s rtmp://live-api.facebook.com:80/rtmp/639512913055273?ds=1&a=AThsCeTXJDMjP689: Input/output error
ffmpeg started on 2018-05-13 at 17:44:44 Report written to "C:\ProgramData\vMix\streaming\streaming 20180513-174444.log" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 692.135000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 25 tbr, 10000k tbn, 25 tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [tcp @ 0dd89cc0] TCP Buffer has been set to 6571008 bytes rtmp://live-api.facebook.com:80/rtmp/639512913055273?ds=1&a=AThsCeTXJDMjP689: Input/output error
Joined: 4/17/2016(UTC) Posts: 3 Location: Lunenburg Ma
Thank Goodness I found this thread.
I have been trying to stream for 2.5 hours with the SAME error. Seems to be a Facebook issue for sure.
I am also facing the same issue, is there any solution yet?
You get what you pay for. Use professional CDNs or maybe for some reason YouTube. But stay far away from Facebook.
ovinas wrote:You get what you pay for. Use professional CDNs or maybe for some reason YouTube. But stay far away from Facebook. That may be true. But Facebook can bring a large audience to your show. No CDN can do that. And not everyone can afford market rates for streaming.
May bring a large audience if it works. These days it's more like plug and pray. And if it works will it work untill the end of your show? Better post a link to your CDN or YouTube stream.
Well this seems to be a an ongoing issue, not sure where we should be reporting this too? I agree facebook is a great marketing tool, we broadcast on a host of public and private CDN's and even the expensive ones have their issues. It happens. Hopefully this will get fixed when everybody gets back to work on Monday and notices it.
Have a good weekend everybody.
