4 Pages123>»
#1 Posted : Friday, April 27, 2018 9:25:50 PM(UTC)
Groups ready for retrieval: Administrators
vMix 21 Preview (21.0.0.32 Beta) is here!
Please Note: This is a preview release for those who like to live on the edge! There will still be some bugs, so it is not recommended for production use.
Your feedback is greatly appreciated, please report any bugs or issues in this thread.
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
http://cdn.vmix.com/download/vmix21preview.exe
New Features and Changes
* New Colour Correction tab on every input
Provides professional 3-way Lift/Gamma/Gain/Hue/Saturation colour correction
with industry standard colour wheels and bars.
* New Waveform Monitor and Vectorscope for Preview and Input Settings
Use RGB icon to select between Waveform, RGB Parade, Vectorscope and split (side by side) display options.
Vectorscope includes skin tone line.
* New independent streaming support
All three streams can now be controlled independently. If one stops the others will continue.
This also allows a different audio bus to be sent to each stream to support multi lingual streaming setups.
* New Square (1:1) and Vertical (9:16) streaming options will automatically crop the sides of the video to fit.
New Square, Vertical Safe Area lines added to assist with adjusting the viewable area.
* MultiView Output now supports custom input layouts instead of 1-8.
Can also be used to assign monitors based on input type, for example to always show the first
4 cameras in the first row regardless of input position.
* Added support for SSL with Facebook, select the Secure Connection tickbox in Facebook settings to enable.
Can also be used to allow streaming to Facebook on networks with web filtering or proxy restrictions.
* New shortcuts:
SetVolumeFade: automates fading of audio based on a custom duration in milliseconds
SetOutput2,3,4
ColourCorrectionAuto
ColourCorrectionReset
SetCCX shortcuts to adjust Lift/Gamma/Gain/Hue/Saturation, with MIDI device support
Start/StopStreaming functions support optional value to select stream number
InputPreviewShowHide: Show and hide the large input preview window
* Improved NDI output support: Outputs can now be toggled without restarting vMix. New advanced output options such as Audio Channel and Alpha Channel.
* Windows Update is now disabled automatically while vMix is running to prevent updates
installing unexpectedly in the background.
* New OnCountdownCompleted trigger for titles
* Inputs.Find in Scripting API now supports numbers in addition to input names
* All dropdown Input lists now include input number first to make it easy to find inputs in large setups
* Improved support for JSON feeds in Data Sources
* Dragging and dropping content into vMix will now be added to recent items to make it easy to find
those items in the future
* New Performance Alerts - If CPU or GPU exceed a certain threshold, an alert will appear in the status
bar at the bottom of vMix.
* X-Keys T-Bar/Jog/Shuttle support added
* Added Activator for MultiCorder
* PTZ Optics ZCAM support
* Support for AJA Io 4K Plus and new Kona HDMI
* New repeat checkbox in vMix Social. When unchecked vMix Social will only display new posts once.
* Improved German translation
* Fixed Focus/Zoom issues with Sony VISCA over IP provider.
* New Activators support in TCP API
For more information on vMix and how it works see the help file:
http://help.vmix.com/21/
thanks 45 users thanked admin for this useful post.
DWAM on 4/27/2018(UTC), mjgraves on 4/27/2018(UTC), corporatejames on 4/27/2018(UTC), DYosua on 4/27/2018(UTC), Len56 on 4/27/2018(UTC), ask on 4/27/2018(UTC), sinc747 on 4/27/2018(UTC), vijay6672 on 4/27/2018(UTC), SHMD on 4/27/2018(UTC), Nick on 4/27/2018(UTC), Video Dave on 4/28/2018(UTC), stigaard on 4/28/2018(UTC), mburel1980 on 4/28/2018(UTC), Stavlin on 4/28/2018(UTC), StepBackInTime_TV on 4/28/2018(UTC), ON.tv Channels on 4/28/2018(UTC), JoseL on 4/28/2018(UTC), floz23 on 4/28/2018(UTC), prass on 4/28/2018(UTC), chiscort on 4/28/2018(UTC), richardgatarski on 4/28/2018(UTC), Zetor1980 on 4/28/2018(UTC), Barney Box Lane on 4/28/2018(UTC), stevespaw on 4/28/2018(UTC), seb666 on 4/28/2018(UTC), h2video.nl on 4/28/2018(UTC), mgrayeb on 4/28/2018(UTC), seomaii on 4/28/2018(UTC), QuiapoChurch on 4/29/2018(UTC), monamiga on 4/29/2018(UTC), digitalalps on 4/29/2018(UTC), Cormac on 4/29/2018(UTC), Ittaidv on 4/29/2018(UTC), dionv on 4/29/2018(UTC), Peter B on 4/29/2018(UTC), BETech on 4/30/2018(UTC), matteoarrigone on 5/1/2018(UTC), Ario on 5/1/2018(UTC), slb5146 on 5/2/2018(UTC), madness on 5/2/2018(UTC), rowby on 5/3/2018(UTC), MycroBeat99 on 5/4/2018(UTC), allayit on 5/7/2018(UTC), RJF on 5/11/2018(UTC), kol0 on 5/15/2018(UTC)
#2 Posted : Friday, April 27, 2018 9:34:19 PM(UTC)
So cool! Thanks
thanks 2 users thanked DWAM for this useful post.
guztavo on 5/1/2018(UTC), Damn2Good4U on 5/8/2018(UTC)
Len56
#3 Posted : Friday, April 27, 2018 9:47:01 PM(UTC)
Len56
Thanks Martin great stuff
ben1000
#4 Posted : Friday, April 27, 2018 10:41:08 PM(UTC)
ben1000
Will this run along side standard vMix on the same computer? Or does it need to be installed on it's own?
Best,
Ben
ask
#5 Posted : Friday, April 27, 2018 11:50:57 PM(UTC)
ask
I have done a couple of installs on different machine with varying specs. In each case I am getting vMixNDIHelper crashes. THese are machines with the NDI/HX drivers installed. vMix seems to be working fine however and I am still able to bring in NDI and NDI/HX sources.
ask
#6 Posted : Saturday, April 28, 2018 12:06:40 AM(UTC)
ask
Best,
Ben
It will overwrite an existing install. You can rollit back however by simply re-installing the old version.
corporatejames
#7 Posted : Saturday, April 28, 2018 12:12:15 AM(UTC)
corporatejames
Andrew Check that Antivirus is not detecting the file on install. I have my Avast do scans on some of the files on install but nothing to worry about.
Could be why it has crashed as AV stopping the file from running temporarily.
ask
#8 Posted : Saturday, April 28, 2018 3:07:31 AM(UTC)
ask
Good idea, but it happens on machines with and without Anti-virus on.
StepBackInTime_TV
#9 Posted : Saturday, April 28, 2018 3:15:30 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
Wow Martin! Fantastic! Thank you so much for all these excellent new features. So many of these are things I hoped vMix would be able to do one day, and now it can!
Many Many Thanks!
Giles.
thanks 1 user thanked StepBackInTime_TV for this useful post.
#10 Posted : Saturday, April 28, 2018 3:24:02 AM(UTC)
ask,
See if this NDI-HX driver resolves the issue:
https://forums.vmix.com/...ts&m=52379#post52379
If not, I would be interested in logging in to the machine remotely if possible
to run some diagnostics, it sounds like the HX source is causing the helper app to crash and I would really like to know why!
Barney Box Lane
#11 Posted : Saturday, April 28, 2018 7:29:32 AM(UTC)
Barney Box Lane
you're absolute legends!! audio fade!! so happy thank you so much
#12 Posted : Saturday, April 28, 2018 7:50:41 AM(UTC)
Best,
Ben
install in another directory
AlanZ
#13 Posted : Saturday, April 28, 2018 1:20:47 PM(UTC)
AlanZ
In customizing the Multiview output in Setup>Otuputs/NDI, for each layout, the available items are two fewer than the selected multiview display...
The first two tiles always show Preview and Output... and then the remaining tiles are available for customization.
For example, in the 16 tile display, there are 14 dropdown lists to configure. In the 4 tile display there are 2 dropdown lists.
The default for each layout should likely have the preview and output as the first two, but as long as we're customizing... the additional flexibility to control all of the tiles could be welcome.
It's not a big thing, but is there a way to configure the entire set of tiles? For example, I might not want to show the preview screen.
thanks 1 user thanked AlanZ for this useful post.
niemi on 4/29/2018(UTC)
niemi
#14 Posted : Sunday, April 29, 2018 4:20:43 PM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
+1
Sometimes we don't need preview and output in the multiviewer either, but only the sources.
Peter B
#15 Posted : Sunday, April 29, 2018 5:35:31 PM(UTC)
Peter B
Colour correction, waveforms and many other new features,
this should be V22
Thanks for this unique product.
#16 Posted : Monday, April 30, 2018 3:53:31 AM(UTC)
vMix 21.0.0.34 uploaded!
Changes/Fixes:
* New Key/Fill output support with compatible Blackmagic devices.
If the device supports Key/Fill a new Alpha Channel dropdown will appear in Settings -> External Output
The following devices are known to work:
-Decklink 4K Extreme / Extreme 12G / Pro
-Decklink Duo 2 / Quad 2 (when Port 1 is configured to Port 1 + 3 mode in Desktop Video Utility)
-UltraStudio 4K / 4K Extreme / 4K Extreme 3 / HD Mini
* Fixed issue with NDI output audio channel selection
* Fixed vMix not closing properly after adding a Blackmagic device that has no video source connected.
* Fixed manual focus issues with Sony VISCA over IP PTZ provider
thanks 8 users thanked admin for this useful post.
BETech on 4/30/2018(UTC), corporatejames on 4/30/2018(UTC), sinc747 on 4/30/2018(UTC), ON.tv Channels on 4/30/2018(UTC), seb666 on 4/30/2018(UTC), stigaard on 4/30/2018(UTC), PrepSpin on 4/30/2018(UTC), monamiga on 5/1/2018(UTC)
suburbazine
#17 Posted : Monday, April 30, 2018 12:27:30 PM(UTC)
suburbazine
What's the determination factor for GPU overload? It seems to be set at the 65% utilization mark.
Priders
#18 Posted : Monday, April 30, 2018 12:38:52 PM(UTC)
Priders
Hi
This is a fantastic update but, the scale for the colour waveform is odd. The lines do not represent 10IRE.
The bottom one is 0 the fourth is 50 and the top, eight line is 100.
Can this be changed to a line every 10 from 0 to 100?
Even better would be -10 to 110 IRE.
Only a suggestion as this is still a fantastic addition to an already great product.
ask
#19 Posted : Monday, April 30, 2018 8:31:04 PM(UTC)
ask
admin wrote:
ask,
Martin, that seems to have fixed it on the more powerful machine. I still get the failure on a low powered Duo-Core test machine I run SD basic on. Not fussed that the error shows there as it is most likely the low spec hardware. I have upgraded a system that does not have the newtek drivers installed and there has been no issue with that at all.
Andrew
Ario on 5/2/2018(UTC)
IrvinCee
#20 Posted : Wednesday, May 2, 2018 12:52:45 PM(UTC)
IrvinCee
I had a fully functional Sony laptop with a discrete GeForce GT740M card in it and with vMix beta 21.0.0.34.
Optimus was on.
I updated to the new Windows 10 April 2018 edition just released yesterday (30 april).
Now when I open vMix I get a "Attempt to read or write to secured memory.." (translated from dutch) and D3DStartup.
NVidia driver is the latest (was already on it). Tried to reinstall the driver but with same result.
Send a couple of error reports to you.
I deleted the vmix config file and reopened but it insists on turning on Optimus with again the same error.
I can turn of the discrete adapter and use the Intel one and then it works but then I can't use the GT 740M for encoding.
Friendly greetings.
Guest (4)
4 Pages123>»
