spencerm24
#1 Posted : Sunday, April 22, 2018 12:59:43 PM(UTC)
spencerm24
Has anyone had any luck getting a MIDI controller such as the Akai APC Mini to work over a KVM ethernet extender. My vMix machine is in a rack room about 100ft away, and is connected via KVM to the computer monitor, keyboard and mouse. Everything else works as normal, but my APC Mini isn't registering any button presses despite being lit up. Anyone have any luck or ideas on a longer run Midi controller?
TuesdaysLive
#2 Posted : Sunday, April 22, 2018 3:17:12 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Machine? OS?
Does the MIDI controller work with any other application?
#3 Posted : Sunday, April 22, 2018 5:14:37 PM(UTC)
@ spencerm24
At what point are you attaching the device?
In order to be recognized by vMix, it needs to be connected before launching vMix and enabled in Shortcuts and Activators settings window.
(not sure if that is the issue or not, but thought I should bring it to everyone's awareness)
rowby on 4/23/2018(UTC)
spencerm24
#4 Posted : Monday, April 23, 2018 9:44:40 AM(UTC)
spencerm24
IceStream wrote:
@ spencerm24
Good point, I did try multiple connection options, rebooted windows, etc, it connects sorta in that the lights light up, and the audio faders work some of the time, but the button's do not function.
