vMix 10 AVI alpha channel issue
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
 Hi Admin, Why on vMix10 when playing AVI alpha channel unlike in vMix9. Is there a solution? Thank you.
Are you clicking the "Video contains alpha channel" tickbox when adding the video?
Martin vMix
admin wrote:Hi,
Martin vMix I've already done it. but the result is the same. do i have to install certain codecs specifically vMix 10?
Hi, Could you confirm which graphics card you are using? Also, would you be able to send the video clip to us for testing? You can use https://fileobject.com/ to upload it. Regards, Martin vMix
Thanks,
Does the AVI use compression at all? Also, can you open up the input settings and provide a screenshot of the advanced tab?
Martin vMix
AVI Alpha channel test.avi https://fileobject.com/ucwznvdhasaarn/I've uploaded a transparent background AVI file. please test in vMix9 and v10. Is it only on my PC, whether it is from vMix10? Because when I test in v9 works well I'm sorry if my english bad. Thank you
I've just tested the video in vMix 10 on Windows 7, 8 and on NVIDIA and AMD cards and the alpha channel works fine. Can you provide a screenshot of the advanced tab in vMix 10 as requested? This will allow me to see if anything strange is happening.
Martin vMix
yeah ... problem has been found!!!!!!. it lies in the LAV Video Decoder. After I uninstalled LAV video codec, is now working fine.
Thank guidance. Good luck
Sontoloyo
