Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The aim is for a Preview (Beta) release of vMix 10 by the end of June.
Martin vMix
Fine! Thanks for the info!
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
admin wrote:The aim is for a Preview (Beta) release of vMix 10 by the end of June.
Martin vMix is wonderful! look confident.... Thank You Martin for the Work.
Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
would be awesome to have asio support on vmix... there`s a great app that i use, asio4all (http://www.asio4all.com/) VERY USEFULL
Rank: Guest
Groups: Guests
Can the two instances of VMix be spun up on a single PC. Then can each instance create a virtual source to feed FMLE? admin wrote:vMix 10 is now well on the way to being completed!
Below is a preliminary list of the new features that will be available:
* New Output Options -Two indendently configurable outputs, 1. Fullscreen 2. Recordings and External Output -These Two outputs can be set to one of the following: --Output --Preview --MultiView (top half of screen Preview/Output, bottom half first 8 inputs) --Input (for example, configure fullscreen to show a single camera while recording the master mix)
-If both outputs are set to Output, the four Overlay channels can be configured independently.
* Improved RTSP compatibility. -I have been given various test streams from cameras and servers that were having issues and implemented fixes. (Including Panasonic and Vivotek)
* Support for Transport Streams (H264/AAC) -This can be used with the Teradek Bond / Sputnik etc
* New API options -Designed to assist with external scheduling apps and hardware controllers -GUID support, Loop toggle, extended XML information
* Multiple Hard Drive support for Multicorder
* Default settings button
Feel free to comment below.
Martin vMix
Hello Martin, I am about 10 times a day to control the release of the beta version of vMix 10 :-) I can not wait .... When is the release? Thank you!
