3 Pages<123
#41 Posted : Tuesday, June 18, 2013 7:08:55 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
The aim is for a Preview (Beta) release of vMix 10 by the end of June.
JOHN on 6/18/2013(UTC)
macjaeger
#42 Posted : Tuesday, June 18, 2013 1:04:03 PM(UTC)
macjaeger
Fine! Thanks for the info!
macgiver76
#43 Posted : Wednesday, June 19, 2013 7:33:59 AM(UTC)
macgiver76
is wonderful! look confident....
Thank You Martin for the Work.
artciukas
#44 Posted : Saturday, June 22, 2013 7:20:30 AM(UTC)
artciukas
would be awesome to have asio support on vmix... there`s a great app that i use, asio4all (http://www.asio4all.com/) VERY USEFULL
melody
#45 Posted : Saturday, June 22, 2013 8:03:09 AM(UTC)
Rank: Guest
Groups:
...requested by melody in this post:
http://forums.vmix.com.a...osts&m=5041#post5041
sportzcast
#46 Posted : Saturday, June 22, 2013 8:25:05 PM(UTC)
sportzcast
Can the two instances of VMix be spun up on a single PC. Then can each instance create a virtual source to feed FMLE?
admin wrote:
vMix 10 is now well on the way to being completed!
Below is a preliminary list of the new features that will be available:
* New Output Options
-Two indendently configurable outputs, 1. Fullscreen 2. Recordings and External Output
-These Two outputs can be set to one of the following:
--Output
--Preview
--MultiView (top half of screen Preview/Output, bottom half first 8 inputs)
--Input (for example, configure fullscreen to show a single camera while recording the master mix)
-If both outputs are set to Output, the four Overlay channels can be configured independently.
* Improved RTSP compatibility.
-I have been given various test streams from cameras and servers that were having issues and implemented fixes. (Including Panasonic and Vivotek)
* Support for Transport Streams (H264/AAC)
-This can be used with the Teradek Bond / Sputnik etc
* New API options
-Designed to assist with external scheduling apps and hardware controllers
-GUID support, Loop toggle, extended XML information
* Multiple Hard Drive support for Multicorder
* Default settings button
Feel free to comment below.
macgiver76
#47 Posted : Friday, June 28, 2013 11:06:25 AM(UTC)
macgiver76
Hello Martin, I am about 10 times a day to control the release of the beta version of vMix 10 :-)
I can not wait ....
When is the release?
Thank you!
#48 Posted : Monday, July 1, 2013 9:16:05 AM(UTC)
3 Pages<123
