ELCHAPIN
#1 Posted : Friday, April 8, 2011 12:19:46 PM(UTC)
ELCHAPIN
Hi all
Greetings
Audio Problems Again
only captures video (DV Cam, firewire).
try everything and nothing
WIN 7 (64)
freezes.
Please take a few tips from experience
not theoretical.
PD
I urge for the weekend
melody
#2 Posted : Friday, April 8, 2011 1:30:59 PM(UTC)
Rank: Guest
Groups: Guests
holla elchapin,
en "Recording Options", no puedes dejar el cuadro de "Audio Device" en "None", por supuesto que no te grabará el sonido.
intenta de canectar el sonido de la camara al pc (Line in).
saludos,
melody
ELCHAPIN
#3 Posted : Friday, April 8, 2011 3:00:04 PM(UTC)
ELCHAPIN
if you try it and nothing
many attempts, I start again
si ya lo intente y nada
muchos intentos , empezare de nuevo
#4 Posted : Friday, April 8, 2011 4:44:14 PM(UTC)
Was thanked: 4749 time(s) in 1632 post(s)
You must have a soundcard installed that supports recording the wave output. Looking at those dropdown options it appears your sound card does not support the option. (Usually Called "What You Hear" or Wave Input or Stereo Mix)
If there is no Wave or Stereo Mix option under the recording settings than your sound card may not support recording in that way.
You can double check this from the Control Panel:
1. Open Control Panel.
2. Go to Sound.
3. Under the Recording tab right click anywhere and click "Show Disabled Devices"
There should now be an option for Wave or "Stereo Mix" you can enable and use in vMix.
ELCHAPIN on 4/8/2011(UTC)
ELCHAPIN
#5 Posted : Friday, April 8, 2011 8:14:04 PM(UTC)
ELCHAPIN
working on analog inputs catch
but not in canon for DV camera firewire cable
There is no option to record audio or video to DV camera device 1.
Option to solve 1
2. Go to Sound.
Well thanks.
But not DV, I will use 2 Second cable
for the audio card
and always used a cable 75 feet cable fire.
Once more THANKS
Martin and
Melody
trabaja en analogo capturas entradas
pero no en DV camara canon por firewire cable
no hay opcion en grabar video para DV audio o dispositivo de camara 1.
Solucione 1 opcion con
2. Go to Sound.
Bien Gracias .
Mas no DV , usare 2 Segundo cable
para la tarjeta de audio
siempre e usado un cable 75 pies cable de fuego.
Una ves mas GRACIAS
Martin y
Melody
