Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hi all Martin Greetings
Audio Problems Again only captures video (DV Cam, firewire). try everything and nothing
WIN 7 (64) freezes.
Please take a few tips from experience not theoretical. Thanks
PD I urge for the weekend
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
holla elchapin,
en "Recording Options", no puedes dejar el cuadro de "Audio Device" en "None", por supuesto que no te grabará el sonido.
intenta de canectar el sonido de la camara al pc (Line in).
saludos, melody
if you try it and nothing many attempts, I start again ==================================== si ya lo intente y nada muchos intentos , empezare de nuevo
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4729 time(s) in 1621 post(s)
You must have a soundcard installed that supports recording the wave output. Looking at those dropdown options it appears your sound card does not support the option. (Usually Called "What You Hear" or Wave Input or Stereo Mix)
If there is no Wave or Stereo Mix option under the recording settings than your sound card may not support recording in that way. You can double check this from the Control Panel:
1. Open Control Panel. 2. Go to Sound. 3. Under the Recording tab right click anywhere and click "Show Disabled Devices"
There should now be an option for Wave or "Stereo Mix" you can enable and use in vMix.
working on analog inputs catch but not in canon for DV camera firewire cable There is no option to record audio or video to DV camera device 1.
Option to solve 1 1. Open Control Panel. 2. Go to Sound. 3. Under the Recording tab right click anywhere and click "Show Disabled Devices"
Well thanks. But not DV, I will use 2 Second cable for the audio card and always used a cable 75 feet cable fire. -------------------------------------------------- ------------------------------- Once more THANKS Martin and Melody
trabaja en analogo capturas entradas pero no en DV camara canon por firewire cable no hay opcion en grabar video para DV audio o dispositivo de camara 1.
Solucione 1 opcion con 1. Open Control Panel. 2. Go to Sound. 3. Under the Recording tab right click anywhere and click "Show Disabled Devices"
Bien Gracias . Mas no DV , usare 2 Segundo cable para la tarjeta de audio siempre e usado un cable 75 pies cable de fuego.
Una ves mas GRACIAS Martin y Melody
