2 Pages12>
RichShumaker
#1 Posted : Friday, August 18, 2017 1:28:45 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
VST plug in's are great for adding audio tricks to any audio production.
Can vMix use VST plug in's natively?
If it can't I would like to add that as a feature request.
The reason this is a feature request and not a general discussion question is that I would also like a 'hard limiter' beyond VST's.
With VST I could add a hard limiter via a plug in.
Heck I could get the Compander for only $39 from Waves.
http://www.waves.com/plugins/c1-compressor
Compressor plugin with gate and sidechain
Compressor/Expander, Gate/Expander, Filter/EQ modules
By Hard Limiter I mean something that keeps audio from going beyond a certain point.
Once it gets close to that point it compresses the signal down so it doesn't peak or spike or go beyond maximum.
I know that vMix has a compressor that could be used to do hard limiting except it is not a 'user friendly' as having a hard limiter.
A simple slider that says NEVER GO LOUDER THEN THIS, literally screaming the volume to the maximum.
Why do I need that?
To avoid going over the maximum volume and 'clipping'.
In audio when you have 3 or 4 or more inputs having the ability to control each ones minimum volume with gates and maximum output via hard limiters you avoid messed up audio.
I see the Master Audio Track using a Hard Limiter as being SUPER USEFUL for everyone using vMix.
Thanks everyone for checking this out and please +1 for VST or for hard limiting or BOTH.
Rich Shumaker
thanks 2 users thanked RichShumaker for this useful post.
IrvinCee on 10/18/2017(UTC), Jeffry_Ghost on 11/23/2017(UTC)
mjgraves
#2 Posted : Friday, August 18, 2017 1:31:23 PM(UTC)
mjgraves
+1
RichShumaker on 11/13/2017(UTC)
RichShumaker
#3 Posted : Friday, August 18, 2017 1:43:14 PM(UTC)
RichShumaker
This Freeware VST plug in calls it a brick wall,
?t=13s
I used the term Hard Limiter.
There are many names except they mean the same thing.
Thanks again for checking this out.
Rich Shumaker
daniel514
#4 Posted : Friday, August 18, 2017 2:17:42 PM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
+1
thanks 1 user thanked daniel514 for this useful post.
kricher1964
#5 Posted : Friday, August 18, 2017 2:39:29 PM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
+1
thanks 1 user thanked kricher1964 for this useful post.
zenvideo
#6 Posted : Friday, August 18, 2017 3:04:43 PM(UTC)
zenvideo
Given that VST audio plug-in support has been requested many times before, and isn't available yet, here's a suggestion for all those who would like to have some sort of limiter but who may not have fully explored the existing audio options.
The general definition of a limiter is a compressor with a compression factor of at least 20:1. vMix offers a compressor on each of its output groups with a ratio up to 25:1, so start by going into the settings for the Master output and set the ratio to 25:1 and enable the Compressor. Now in theory you could set the Threshold to around -4dBfs and be protected from peaking past 0dBfs, but the attack isn't as fast as is needed for a digital "brick-wall" limiter, so you need to set the threshold somewhat lower. In fact this is an "AOT" value (Adjust On Test), meaning you may need to experiment a bit depending on the type of audio content you're passing through it (e.g. speech or music, where speech may need a lower threshold value than music). A value between -18 & -10dB would be a good starting point.
This is far from being the best possible limiter, but if you're restricted to using the tools within vMix (as opposed to doing all audio mixing/processing externally) then it can prove quite effective with some (but not all) types of audio content. With more control over attack/decay times it could probably be more effective as a limiter.
thanks 3 users thanked zenvideo for this useful post.
sinc747 on 10/18/2017(UTC), Ario on 4/24/2018(UTC), Ronald555 on 4/30/2018(UTC)
Sojourner
#7 Posted : Friday, August 18, 2017 5:12:48 PM(UTC)
Sojourner
thanks 1 user thanked Sojourner for this useful post.
dsolomon
#8 Posted : Friday, August 18, 2017 6:17:46 PM(UTC)
dsolomon
+1 - we use Stereo Tool on our radio stations and would love to use it in VMix.
thanks 2 users thanked dsolomon for this useful post.
PFBM on 8/18/2017(UTC), RichShumaker on 11/13/2017(UTC)
PFBM
#9 Posted : Friday, August 18, 2017 6:33:06 PM(UTC)
PFBM
Views messages in topic : 311
Was thanked: 36 time(s) in 31 post(s)
HI !!
i use StereoTool on vMix with a workaround.....
yes it works, but ... you have to sinc the audio with the video... with vmix audio time delay...
use this 2 apps :
https://o-deus-audio.com.au/ASIOLinkPro
and :
http://www.niallmoody.com/apps/pedalboard2
Cheers,
PFBM
PS: put stereotool in multicore cpu to lower latency :)
RichShumaker
#10 Posted : Wednesday, August 23, 2017 11:01:02 AM(UTC)
RichShumaker
PFBM wrote:
Cheers,
PFBM
Thanks for this I will check it out.
Also I do use the internal audio tools to do things and the compressor usage above by "zenvideo" is what I was discussing that you can currently do when I said "I know that vMix has a compressor that could be used to do hard limiting except it is not a 'user friendly' as having a hard limiter."
Honestly what I have been hoping for is some type of NDI audio support in a program that would allow round tripping the audio.
Similar to what you are discussing except with NDI.
Many people are using NDI with titles and screen captures so why not audio.
Basically you would have a PC for Audio that would NDI over to vMix and yes I know I could just as easily do an Analog output from PC one to PC two Analog Input, heck I could even make a digital signal path. At the end of the day having it all in one place is much more straight forward.
Add On to my request if adding VST is near impossible, which it might be, how about adding HARD LIMITING to the existing compressor tool?
Thanks again everyone for all the help and suggestions I greatly appreciate it.
Rich Shumaker
banovina
#11 Posted : Friday, September 15, 2017 2:21:34 PM(UTC)
banovina
+1
thanks 1 user thanked banovina for this useful post.
Murchik
#12 Posted : Friday, September 15, 2017 3:30:11 PM(UTC)
Murchik
Ukraine
very interesting topic! I with a sound card external from M-AUDIO has received license plug-ins WAVES, but I can not use in VMIX though very much hochetsja
thanks 1 user thanked Murchik for this useful post.
voiceovercity
#13 Posted : Wednesday, October 18, 2017 4:18:40 PM(UTC)
voiceovercity
+1
thanks 1 user thanked voiceovercity for this useful post.
avsoundguy
#14 Posted : Thursday, October 19, 2017 10:56:26 AM(UTC)
avsoundguy
+1
thanks 1 user thanked avsoundguy for this useful post.
Teye
#15 Posted : Monday, November 13, 2017 12:26:30 PM(UTC)
Teye
+ 1
thanks 1 user thanked Teye for this useful post.
JimJacobs
#16 Posted : Monday, November 13, 2017 1:26:38 PM(UTC)
JimJacobs
The ability to use the OptiMaxx plug-in would be one of the best solutions for compressor/limiter. We use it on all or audio streams and it works and sounds fantastic
thanks 1 user thanked JimJacobs for this useful post.
RichShumaker
#17 Posted : Wednesday, November 22, 2017 9:37:27 PM(UTC)
RichShumaker
Thanks vMix you never disappoint.
Added to the newest version that comes out later today.
VST 3.0 64bit support just announced on Fun Time Live Show
WOOHOO
SHMD on 11/22/2017(UTC), mjgraves on 11/23/2017(UTC)
SHMD
#18 Posted : Thursday, November 23, 2017 1:10:08 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Already did some testing with my Waves and iZotope VST3 64bit plugins on the master and it looks like it will add much more audio control with very little CPU hit.
Great addition!
thanks 1 user thanked SHMD for this useful post.
RichShumaker on 11/23/2017(UTC)
rrpro
#19 Posted : Thursday, November 23, 2017 3:31:47 AM(UTC)
rrpro
In my computer it didn't find all the plugins. Any way to locate the DLL?
SHMD
#20 Posted : Thursday, November 23, 2017 11:49:34 AM(UTC)
SHMD
Canada
So nice to use my fave plugins in vMix - iZotope Ozone, Waves SSL E-Channel, eMo D5 and BSS DPR-402.
SHMD attached the following image(s):
thanks 2 users thanked SHMD for this useful post.
mjgraves on 11/23/2017(UTC), RichShumaker on 11/23/2017(UTC)
2 Pages12>
