NDI
USB Cameras and NDI
Joined: 12/16/2016(UTC) Posts: 9   Location: Mount Rose
Can USB cameras plugged into one Vmix system be used on a separate Vmix computer? I see the USB camera on the second computer NDI/Desktop Capture but I only get a Black Screen?
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
drhurd wrote:Can USB cameras plugged into one Vmix system be used on a separate Vmix computer? I see the USB camera on the second computer NDI/Desktop Capture but I only get a Black Screen? You may need to use a dedicated WebCam to NDI app instead of screen capture. On Mac use Sienna WebCam for NDI On Windows use NewTek NDI Connect Pro
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 321 times Was thanked: 263 time(s) in 233 post(s)
Yes. I have vMix on my laptop and on my desktop. I can set the laptop camera as a source in vMix-1. Then go into vMix-2 on the desktop, see the laptop camera exposed as an NDI source, and select it as source for the desktop project.
Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
Mjgraves,
I think that means no need to purchase newtek connect pro to see a usb webcam if you have two versions of vMix. Correct???
Thank you very much.
RobLambert wrote:Mjgraves,
Thank you very much. Right! Two copies of vMix gets it done. You can have the Basic HD version on the contributing computer. A more capable version on your main system.
Thank you very much. Or use the free version of NDI Connect which supports up to two sources on single machine. Kane Peterson NewTek
 1 user thanked kane for this useful post.
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
I've used OBS to achieve that before.
Haven't tried Newtek's Connect...
NDI
USB Cameras and NDI
