drhurd
#1 Posted : Monday, October 23, 2017 12:27:00 AM(UTC)
drhurd
Can USB cameras plugged into one Vmix system be used on a separate Vmix computer? I see the USB camera on the second computer NDI/Desktop Capture but I only get a Black Screen?
livepad
#2 Posted : Monday, October 23, 2017 3:34:23 AM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
You may need to use a dedicated WebCam to NDI app instead of screen capture.
On Mac use Sienna WebCam for NDI
On Windows use NewTek NDI Connect Pro
mjgraves
#3 Posted : Tuesday, October 31, 2017 4:36:55 PM(UTC)
mjgraves
Yes. I have vMix on my laptop and on my desktop. I can set the laptop camera as a source in vMix-1. Then go into vMix-2 on the desktop, see the laptop camera exposed as an NDI source, and select it as source for the desktop project.
RobLambert on 11/2/2017(UTC)
RobLambert
#4 Posted : Thursday, November 2, 2017 6:43:40 PM(UTC)
RobLambert
Mjgraves,
I think that means no need to purchase newtek connect pro to see a usb webcam if you have two versions of vMix. Correct???
Thank you very much.
mjgraves
#5 Posted : Friday, November 3, 2017 5:52:35 PM(UTC)
mjgraves
RobLambert wrote:
Mjgraves,
Right! Two copies of vMix gets it done. You can have the Basic HD version on the contributing computer. A more capable version on your main system.
RobLambert on 11/6/2017(UTC)
kane
#6 Posted : Friday, November 3, 2017 11:23:47 PM(UTC)
kane
RobLambert wrote:
Mjgraves,
Or use the free version of NDI Connect which supports up to two sources on single machine.
Kane Peterson
NewTek
thanks 1 user thanked kane for this useful post.
RandomStreamer
#7 Posted : Tuesday, November 7, 2017 5:23:11 PM(UTC)
RandomStreamer
I've used OBS to achieve that before.
Haven't tried Newtek's Connect...
Guest (4)
