2 Pages12>
roverradio
#1 Posted : Tuesday, September 20, 2016 8:59:13 PM(UTC)
roverradio
We use Stingers to come back from commercial break, then to immediately go into features (like breaking news, etc.).
But you have to switch them out since there are only 2.
Why not have many more that you could easily map?
Thanks!
#2 Posted : Tuesday, September 20, 2016 10:09:23 PM(UTC)
+ 1
Or at least be able to have a shortcut to easily swap them out.
corporatejames on 4/22/2017(UTC)
sinc747
#3 Posted : Wednesday, September 21, 2016 2:17:42 AM(UTC)
sinc747
+1 good.
Peter B
#4 Posted : Wednesday, September 21, 2016 3:18:55 AM(UTC)
Peter B
There is another thread about this at the bottom of page 1.
Agree. A work around is using an overlay and then triggering a background transition behind the overlay at some point. This has the advantage of being able to use transitions other than a cut when the stinger graphic doesn't go full frame to mask the cut.
madness
#5 Posted : Wednesday, September 21, 2016 9:35:06 AM(UTC)
madness
You could always automate the stingers using the web API to replace the stinger inputs and config for each additional stinger source.
madness
#6 Posted : Wednesday, September 21, 2016 10:17:18 PM(UTC)
madness
Never mind that! Spent tonight looking into it myself, and it appears that you cannot change inputs of stingers without going into the overlay settings. The API doesn't appear to have functions to change those settings. That would be a great feature request as well.
Ed Tech
#7 Posted : Tuesday, October 4, 2016 12:03:54 PM(UTC)
Ed Tech
+1 to go to 4 stingers if possible.
xaver
#8 Posted : Saturday, April 22, 2017 2:44:40 PM(UTC)
xaver
+1
for 4 stingers
mmorlan62
#9 Posted : Saturday, April 22, 2017 6:00:00 PM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
+1
Ignore my other thread about stingers. I need as many as six stingers for my live shows.
mmorlan62
#10 Posted : Saturday, April 22, 2017 6:25:10 PM(UTC)
mmorlan62
I played around with a list feeding a stinger and see the potential. If my list of stingers can find one common cut point, then that would take care of my needs. Set the stinger length to the longest animation in the list and an empty frame at the end of everything and I'm good to go.
I could produce a show with two choices of cut position - say 30 frames and 60 frames - and compose all of my stingers to fit within those two constraints. That would only be a deal-breaker if I needed three stingers with a single-frame flash at three different points. But, it's good to design around known constraints. It makes you stronger. ;-)
Michael
jaredquinn
#11 Posted : Friday, May 5, 2017 12:08:44 AM(UTC)
jaredquinn
+1.
We use stingers for a general event stinger and a replay stinger; and unable to use any more - we would if we could.
mneth2000
#12 Posted : Saturday, May 6, 2017 11:20:54 AM(UTC)
mneth2000
+1
ask
#13 Posted : Friday, September 29, 2017 6:09:45 AM(UTC)
ask
+1 The use case for me is an IMAG gig I have atm. Would also like to see shortcut support for selecting stinger inputs.
alexandrelinhares1
#14 Posted : Friday, September 29, 2017 9:05:52 AM(UTC)
alexandrelinhares1
+1
g-mo
#15 Posted : Friday, October 13, 2017 6:21:14 PM(UTC)
g-mo
+1
fitchew101
#16 Posted : Thursday, October 26, 2017 4:22:16 PM(UTC)
fitchew101
I have been in the progress recently of making our own stingers for each championship we film live.
I have been using After Effect to make a 1-2 second stinger at 30-50fps... Then rendering with After Effects as PNG - You can then bring this into vMix as an image sequence then configuring the overlay for the stinger mix point. Works really well.
Hope this helps, and if i can help at all, will be happy to.
James
SHMD
#17 Posted : Sunday, October 29, 2017 7:21:52 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
+1 Please additional stingers would be great for our productions
Ittaidv
#18 Posted : Sunday, October 29, 2017 9:53:02 AM(UTC)
Ittaidv
+1, more is always better :)
NHT
#19 Posted : Thursday, November 2, 2017 10:21:38 AM(UTC)
NHT
I'm fairly new here guys so don't flame me but this is already achievable by using shortcuts and triggers.
File Attachment(s):
stingerss.avi (2,117kb) downloaded 18 time(s).
RobLambert
#20 Posted : Friday, November 3, 2017 4:46:10 PM(UTC)
RobLambert
+1
Guest (4)
Similar Topics
More stingers please (Feature Requests)
by mmorlan62 4/22/2017 11:05:59 AM(UTC)
Need more stingers! (Feature Requests)
Belarus snitzer 9/9/2016 6:22:42 AM(UTC)
2 Pages12>
