Joined: 1/23/2013(UTC) Posts: 65  Thanks: 3 times Was thanked: 7 time(s) in 5 post(s)
Hi all. I've enjoyed the stingers as part of my live shows. Thanks for being so responsive by adding that only a month after my initial request.
It would be good to have a few more stinger slots. I may have up to six different animations for my shows.
Thanks,
Michael
+ 1 @ mmorlan62 I believe this has been requested before so it might be best to add your support there: https://forums.vmix.com/....aspx?g=posts&t=6936A workaround is to place your Stingers in a "List" and rotate through them, not a perfect solution, especially if the cut points are not the same, but it might be an option for you in the meantime. Ice
Copy that. I'll join the other thread.
I suppose I could create stingers with the same cut point and swap as you note.
